Author Topic: LED Tail Lights  (Read 2700 times)
Benz280
  • USA, NJ, Jersey City
LED Tail Lights
« on: May 01, 2020, 16:09:15 »
Does anyone have experience with replacing brake lights with LED ?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: LED Tail Lights
« Reply #1 on: May 01, 2020, 17:56:23 »
Several of us
Indicators are a challenge (relay voltage)
Rest are simple. Even I managed it
https://www.sl113.org/forums/index.php?topic=22863.0
  • USA, WI, Mequon
Re: LED Tail Lights
« Reply #2 on: May 01, 2020, 19:28:03 »
Check out superbriteleds.com  look for the base you need and then watch the brightness ratings (lm).  Get the longest one that will fit in the space.  Remember, select the color of the lens for greatest brightness, red for red lens, amber for amber lens, etc.  They also have flashers that will operate the bulb, which you will need.  I haven't done my 113, but did do a Jaguar XKE.  Wow!
Jagbct42
Re: LED Tail Lights
« Reply #3 on: May 19, 2020, 15:03:29 »
Brake lights were easy.  Hesitant to do the turn signals because of the fast flashing.  Does anyone know why the LEDs are marked "For off road use only"?
Chris Long
  • USA, NJ, Morristown
Re: LED Tail Lights
« Reply #4 on: May 19, 2020, 15:13:19 »
https://www.sl113.org/forums/index.php?topic=30927.0
Probably because the LED are not DOT approved.
1970 280sl 4-Speed Horizon Blue
Re: LED Tail Lights
« Reply #5 on: May 19, 2020, 15:16:03 »
There's been debate (online) in the UK about this so I called my insurer and told them exactly what I was doing and whose lights I was buying. They were fine with it. I figured brighter rear lights (in particular brake lights) was a good thing.
Sidelights and Headlights are halogen. Indicators are stock. Parking, fog, brake and rear lights are all LED now
