Author Topic: Distributor VJUR 6BR 49T Only One That Fits 230SL?  (Read 3707 times)
mistertj
  • USA, FL, Satellite Beach
« on: May 01, 2020, 22:55:32 »
Most every time I order points for my 1964 230SL, I get the wrong points. Were there other distributors used in the 230SL and if so, what were they? Finding an affordable VJUR 6BR 49T is a rarity. Would be nice say if a 47T also fits.
Re: Distributor VJUR 6BR 49T Only One That Fits 230SL?
« Reply #1 on: May 01, 2020, 23:04:39 »
Have you thought of 123 Ignition?
« Reply #2 on: May 02, 2020, 05:26:07 »
There were at least three different units used on 230SL. The 49T  is one of the earlier ones and the 051 was the last one used when they went to ignition retard.
« Reply #3 on: May 03, 2020, 10:22:46 »
The '49T' is the rarer vacuum advance distributor. A good replacement would be the later 0 231 116 046 distributor (Also, vacuum advance)
You probably always get the wrong points because they would be for the more common later '051' vacuum retard distributor.
Check the 'wiki' for the correct parts numbers for the points and other related parts.
Berggreen
  • Denmark, Zealand, Gentofte
« Reply #4 on: May 03, 2020, 10:49:26 »
I would definately get a 123ignition. Makes the car so much better, instead of constantly battling with the old BOSCH distributors and their wear, points, condensates etc. :)
/Christian
02/1971 MB 280SL (aut.) - olive green 291H
11/1970 MB 280SL (man.) - silver 180G
12/1977 MB 350SE (aut.) - deep green 825H
03/1969 Volvo 1800S (man.) - dark green 94
« Reply #5 on: May 03, 2020, 11:45:44 »
I think so. And clean and oil your original piece, get spare parts for it if needed, wrap nicely and put on shelf.
The immobilizing function in the bluetooth units is also very re-assuring to me.
« Reply #6 on: May 03, 2020, 17:03:43 »
As a fun fact, the VJUR 6 BR 49T was used on my 1960 220SE W128. Probably the first use of that distributor. They were swapping distributor models around like mad about that time. That car and my W111 both have the 123 in it now and I have never looked back.
