Thanks for your help and comments.
I have the manual, and I have been following it point to point during installation, but thanks for sharing. The issue I have, is the same as Chumps has described in another post (
https://www.sl113.org/forums/index.php?topic=23611.0). The green LED that is meant to help position the distributor does not turn on, and I have close to zero volt at the coils (+) terminal point (where the red 123 cable is connected). However, once I disconnect the distributor's red cable from the colis (+) terminal point I get 12 volt.
I have not connected the black cable from the 123
The coil is not grounded from (-) terminal point - nothing is connected to (-)
My 123 does not have a blue cable
I tested the green LED by connecting the red 123 cable directly to (+) at the battery, and it worked
