Author Topic: FIXED: Small, but annoying rear-view mirror issue  (Read 1497 times)
Ulf
« on: May 04, 2020, 18:22:23 »
The interior rear view mirror in my early (built 64') 230 has begun to dangle around on its swivel to the point where I have to adjust it every time I've driven over even minor imperfections in the road surface - can it be tightened somehow? Or can I add something - eg. Loctite to the swivel to make it stop? I know it's a minor issue, but it's driving me nuts :-)
Br
Ulf
« Last Edit: May 12, 2020, 12:03:43 by Ulf »
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
cabrioletturbo
  • Canada, Ontario, Ottawa
Re: Small, but annoying rear-view mirror issue
« Reply #1 on: May 04, 2020, 18:32:26 »
Open it up and tighten the screw. Remove the plastic retainer around mirror glass with care. The mirror glass is spring-loaded, just press it slightly to release tension on the retainer, then start the removal.
Igor
WRe
« Reply #2 on: May 04, 2020, 19:59:03 »
the early interior rear view mirror can be opened very easy and tightened with central screw, see picture.
...WRe
Ulf
« Reply #3 on: May 04, 2020, 21:04:25 »
Great, thanks to both of you :-)
2008 Jaguar XF 3.0
2005 Mini Cooper
