Author Topic: fuel pump impeller  (Read 1519 times)
MP
  • United Kingdom, England, Lydeway Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
fuel pump impeller
« on: May 05, 2020, 17:57:29 »
I have taken my non working pump apart and this is what I have got, it looks like it might be dirty petrol has made grooves in the impeller and other surfaces.
The filter was partly blocked which I have cleaned. Is the pump any good with the grooves or should I bin it?
Grateful for any opinion.
Maurice
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
mistertj
  • USA, FL, Satellite Beach
Re: fuel pump impeller
« Reply #1 on: May 11, 2020, 22:51:11 »
It depends on what pressure the pump will deliver. If you can get 10 to 11 psi, you could continue to use the pump. As for "binning " it, the good parts on the pump can be sold, so they are not trash.
« Reply #2 on: May 12, 2020, 14:59:37 »
Check with our group's resident expert on fuel pumps and impellers.  Bob Youngman.
