Author Topic: Air scoop rubber seal glue  (Read 3664 times)
col320ce
« on: May 07, 2020, 02:10:23 »
I'm assuming this should be glued in place? Use windscreen polyurethane stuff?
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
Aaron h
Re: Air scoop rubber seal glue
« Reply #1 on: May 07, 2020, 06:35:26 »
At the factory they used a contact cement.....it's still available from Mercedes (part number 000-989-92-71-09) or Teroson through a distributor.  It's costly, and has a short shelf life, but is the best contact cement I've ever used.  I also use it for when I do leather/vinyl work on interiors, tight/odd shaped corners in carpeting, and it's an excellent glue for soft top installation.  It also has a moisture resistance that others brands pale in comparison to.
col320ce
« Reply #2 on: May 07, 2020, 09:38:03 »
Thanks Aaron... I have to do the interior of both cars so it's probably a good investment. Is this what you'd use for the bonnet/hood insulation on the later cars? There's a w123 I need to put it on.
Thanks!
Col
1964 230SL
1965 250SE coupe
Aaron h
« Reply #3 on: May 08, 2020, 02:30:24 »
No, a different type of glue is used for the hood pad insulation.  It's still a contact cement, but of a much thinner consistency.  Part number 000-989-82-71.  It comes in a quart can with a lid that pries off much like a paint can.  You'll apply the product with a foam or bristle brush, but quickly, as this product has a shorter flash time.  This glue is also used to adhere the wool pad to the door cards, or any other large surface area textile that needs to be glued.
Alternatively, you can use Permatex or 3M brand heavy duty adhesive in an aerosol spray can.  It does just as good of a job.
« Reply #4 on: May 08, 2020, 09:55:03 »
A friend turned me on to this glue.  It is a sprayable HHR (High Heat Resistant) contact cement.  I use it for everything. Available in gallons only.
« Reply #5 on: May 08, 2020, 13:47:37 »
This gun.
col320ce
« Reply #6 on: May 10, 2020, 02:22:14 »
Looks like the door rubbers are glued on as well! I was expecting clips. (250se coupe)
Col
1964 230SL
1965 250SE coupe
« Reply #7 on: May 10, 2020, 05:09:22 »
For door rubbers you need a different glue! If it is rubber use 3M weatherstrip adhesive 08008. If it is a new seal then it is most likely made of EPDM (not rubber) and then you need 3M weatherstrip adhesive 08011. Here some earlier discussions:
https://www.sl113.org/forums/index.php?topic=25682.msg183885#msg183885
and especially pay attention to Joe's advice here to remove the "mold release" powder from the new seal:
https://www.sl113.org/forums/index.php?topic=14415
There are also some useful videos:
https://www.youtube.com/watch?v=6PbKfw8COQs
https://www.amazon.com/3M-08011-Black-Weatherstrip-Adhesive/dp/B0002SQTVY?th=1
col320ce
« Reply #8 on: May 10, 2020, 12:49:43 »
Thanks for the tips! I've found the 3M 08011 locally.
They're all new seals so I assume they're are epdm.
Col
1964 230SL
1965 250SE coupe
