I re gapped the spark plugs to .030, and there was still a bad miss. I then changed the HT line from the coil to the distributor with a Bosch brand wire, and the coil arch problem was gone. While I was inspecting the rest of the HT wires, I got shocked. I decided to change out all of the spark plugs wires as well, and the idle cleaned right up. The existing plug wires were a very, very good copy of the Bosch brand, but were a knock off (a brand that I did not recognize). When the old black top coil was in the car, the aftermarket wires worked just fine, but when the red top coil was installed it would seem that that was too much current for the aftermarket brand to handle. Seems to run great, and tomorrow I will give her a street test drive. Now it is 100% Bosch and no more issues. Thank you, GCW
