Author Topic: Wanted to buy sedan crank pulley and bracket for AC installation  (Read 3388 times)
Mpgeslak
  • USA, GA, Greensboro
I am installing AC in my 1967 250SL and am looking for the sedan bracket used  during the time of our cars that has been described in several posts on the forum, and is seen in the attached photo.  I also believe I will a new crank pulley with two grooves.
Does anyone have these for sale or can point me in the right direction to acquire them.
Thanks for any help!
I have the crank pulley in stock.
£200 plus VAT.
You will need a slightly taller neck on the themostat housing top also.
Mpgeslak
Joe,
Thanks for the guidance.  I read your earlier post on using the Sedan parts to mount an AC unit in our cars and I have managed to source a thermostat housing top with the taller neck!  Do I have it right that the thermostat housing, crank pulley and the bracket in the picture from your earlier post are the parts I required in addition to the actual AC system?
Stick,
How do I contact you about the part?
Thanks to both of you.
Michael
Stick,
Michael
I know you've already messaged me Michael but for any body else either by PM or my website which is always linked at the bottom of every post I make.
If your car had the factory /dealer AC, then the rubber/metal vibration dampner is also different on the sedans. If your car never had AC then the vibration dampner is correct.
