Author Topic: FIP Query  (Read 1424 times)
Richard S
  • USA, WA, Anacortes
FIP Query
« on: May 08, 2020, 23:59:09 »
Early 250SL, Euro.  With the engine running I noticed a lot oil coming out the red filler cap.  With the engine stopped I removed the FIP dipstick and oil flowed out.  Time for a rebuild!  The tech manual says that this pump has a self contained oil supply so what is the function of what looks like an oil line coming from the block to the inside front of the FIP?
Richard
250SL RHD
Midnight Blue
Aaron h
Re: FIP Query
« Reply #1 on: May 09, 2020, 15:06:27 »
The area where the oil line connects to the injection pump is lubricated from the engine oil pump.  The roller tappets and camshaft/camshaft bearings are lubricated from this oil line.  The oil drains out of the front of the injection pump back into the crankcase.  The rear of the pump (the governor housing) has it's own separate oil supply.  Hence, the filler cap and dip stick.  It is supposed to be separated from the front part that is lubricated from engine oil pump.  There are o-rings around the outside of the steel tappet liners that keep engine oil from the engine getting into the governor housing.  When these o-rings get old, hard, and shrink the ensuing resultant problem is what you are currently experiencing.  So yes, it's time for a thorough rebuild.  However, the later pumps do not have this set up.
Richard S
Re: FIP Query
« Reply #2 on: May 10, 2020, 01:41:11 »
Thank you Aaron.  Very helpful.
Richard
250SL RHD
Midnight Blue
