Author Topic: 4 ring Pistons for early ‘63-‘64 230sl  (Read 3803 times)
Anosh
  • India, Maharashtra, Mumbai
« on: May 09, 2020, 09:57:53 »
Hello.
I am looking to buy a set of new standard size 82mm (4 rings) pistons for my early ‘63-‘64 230sl (like pic below). I am informed that a German manufacturer has announced that these pistons would be available in June for €100 including rings. Would appreciate if someone could give me the name of the manufacturer.
I am also looking for a restored distributor for the same car.
Would appreciate your assistance.
anosh.shroff@gmail.com
johnk
  • USA, OH, Avon
Re: 4 ring Pistons for early ‘63-‘64 230sl
« Reply #1 on: May 09, 2020, 19:36:42 »
Boy would that be a wonderful upset to the 230 parts market at 100 per piston! I am surprised that they would offer them at such a low cost though.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #2 on: May 09, 2020, 20:18:51 »
Hello.
Do you have a distributor number? Maybe a 49T?
cabrioletturbo
  • Canada, Ontario, Ottawa
« Reply #3 on: May 09, 2020, 20:58:55 »
It was a common joke where I come from re: cheap piston rings that they were cut out of stove exhaust pipes. I would not expect better @ $100 for a set. Maybe $100 per piece?
Igor
Anosh
Distributor
« Reply #4 on: May 13, 2020, 15:22:01 »
Hi. The distributor I presently have is JFUR6, Bosch-No. 0 231 116 051.
Anosh
« Reply #5 on: May 13, 2020, 15:24:31 »
Maybe you are right. Will go with the OEM Mahle pistons.
Re: Distributor
« Reply #6 on: May 13, 2020, 15:48:36 »
That should be the unit for a late 230SL, 250SL, and early 280SL.  Look to see if your vacuum line plugs on to the bottom or top of your throttle valve housing.
Anosh
« Reply #7 on: May 14, 2020, 07:41:26 »
Hi.
The car is in the repair shop and we are in very strict lock down. I have attached two pics. One of the distributor fixed on the car (sorry not a good pic) and one of a similar distributor. I am told that these are for the later pagodas. Mine is an early '63 model. Will this type of distributor make a difference in the running of the engine? Or are they interchangeable. If not, I need to get the earlier one for my car.
Many thanks.
