Author Topic: W111 window rubber issue  (Read 2484 times)
col320ce
« on: May 10, 2020, 22:40:03 »
I'm installing the window rubber and the rubber is not lining up where it changes from the front window to the rear window. I'm I supposed to start here and work forwards?
I'm using KY jelly to help get it in.
And tips??
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Aaron h
Re: W111 window rubber issue
« Reply #1 on: May 10, 2020, 23:01:30 »
You start at this point and work your way out.  The ends of the seal may have to be "cut to fit".  Especially on the front end where it meets the top of the door seal.  No lubrication should be necessary.  You use a plastic tool to push in the rubber lips into the chrome rail.
col320ce
« Reply #2 on: May 11, 2020, 02:45:10 »
Thanks Aaron
It's all in!
How low should it be below the chrome trim at the front? (see photo).
Any advice on the glue for the window runner?
I assume it is the same as the door seal?
Col
1964 230SL
1965 250SE coupe
Aaron h
« Reply #3 on: May 11, 2020, 22:03:13 »
Yes, you can use the same glue I mentioned on your other post for the window run felt.
There is no standard length to cut the seal where it meets the door seal.  These cars were hand built, and each car was different.  You simply have to "cut to fit", and to a point to where the door seal presses up against the roof rail seal at an angle when the door is closed.  Use your old seal for a reference as to what angle and direction to cut it at.  This is the very last thing you'll do.  Don't do it before you put things back together.
col320ce
« Reply #4 on: May 12, 2020, 03:27:54 »
Thanks Aaron
Col
1964 230SL
1965 250SE coupe
