Author Topic: Hood Bonnet rubber  (Read 1703 times)
kampala
  • USA, CA, Beach Cities
Hood Bonnet rubber
« on: May 13, 2020, 16:59:42 »
Stripping the inside of the Hood - getting it ready for epoxy primer - and have found a “rubber” strip between the hood structure and the hood panel.  The strip is about 15mm wide and a little less than 2mm thick.  I would assume it has shrunk in thickness.
Does anyone know if this is factory, probably to cushion any rattle?   It does seem to be all the way around.  Due to it cracking, I am removing it and expect to replace.
BTW - you can see the original beige-gray metallic as I remove the ivory paint.
250sl - later - manual
280sl - 1971 - Auto - LSD
Re: Hood Bonnet rubber
« Reply #1 on: May 13, 2020, 17:21:17 »
We just finished a hood where we split the two halves and then used panel bonding to put them back together. All of the outer seams were also spot welded. I didn't see any rubber buffer in between the top and bottom pieces.
chumps
  • USA, CA, Santa Rosa Valley
« Reply #2 on: May 13, 2020, 18:01:19 »
I have that exact same rubber in my hood. 1972 289 SL It has hardened and is coming out in pieces.
chumps
« Reply #3 on: May 13, 2020, 18:02:14 »
Excuse my typo 1971 SL
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #4 on: May 13, 2020, 19:09:31 »
found same on my 64 230 hood
1964 230SL
kampala
« Reply #5 on: May 14, 2020, 04:04:37 »
Thank you very much for all the replies and the photo. Appreciated
