Author Topic: Hood Mounting and Alignment  (Read 1728 times)
Harry
  • USA, TN, Knoxville
« on: May 18, 2020, 23:44:51 »
I just mounted my hood and aligned it, just to find when complete that it is very close but not just right.  Do we have procedure that works best?  I do want to align it better soon.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Hood Mounting and Alignment
« Reply #1 on: May 19, 2020, 06:05:23 »
Where are your fit problems?
WRe
« Reply #2 on: May 19, 2020, 06:57:47 »
there are only 2 possibilities to align the hood:
- Horizontal: At the hood hinge/mounting
- Vertical: At the inner fender
Most problems are loose and rusted nut cages at the hood and broken mountings, see pictures.
Possible repairs: New cage nuts.
...WRe
WRe
« Reply #3 on: May 19, 2020, 07:00:30 »
....more pics
...WRe
WRe
« Reply #4 on: May 19, 2020, 07:01:32 »
... and more for repairing.
...WRe
Harry
« Reply #5 on: May 19, 2020, 10:04:53 »
The fit problems are most obvious at the cowl.  The gap is tight on the passenger side, almost touching but not quite.  The driver's side is not as bad and is close to acceptable.  The vertical fitment along the periphery seems OK.  So I expect that the adjustment must be in the mount points on the hood itself (and not so much on the hinge points on the body).  The difficulty is adjusting the points on the hood without losing the point of reference that you're adjusting "from".  Wouldn't it be great if you could put the hood in the correct position (correct gaps) and simply tighten the bolts from below?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #6 on: May 19, 2020, 22:36:58 »
Open the hood completely loosen the two bolts on the passenger side just enough to move the hood downward with it open. Tighten and close slowly while checking for any clearance problems at the grille screen or front body panel. The gap at the cowl should be better?
