Author Topic: Brake and clutch pedal size  (Read 2161 times)
Guernsey70
« on: May 19, 2020, 21:33:49 »
Crazy question fellas, but I have a 67 230 sL 4 speed.  I want to replace the brake and clutch pedal covers. I ordered ones from BudzBenz AND MB Classic center.  They both seem too small to fit without heavy modification.
Any thoughts?  Is there a certain size of the pedal that is “standard size” vs maybe a larger replacement size prior to my ownership.  The MB Classic guy assured me that they’d fit, but I’m not able to make it work, and they have that slanted/round rubber backing, which doesn’t help.
Thoughts?
Thanks.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Brake and clutch pedal size
« Reply #1 on: May 19, 2020, 21:41:52 »
They can be a really tight fit and difficult to put on.  Try using a little lubricant.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Guernsey70
« Reply #2 on: May 19, 2020, 21:44:24 »
Thank you.  Will try, but seems too tight/small
Paul & Dolly
  • i Car
« Reply #3 on: May 19, 2020, 21:55:01 »
Hi guernsey
Have you tried to put them in Hot Water for a while, makes them softer and easier to fit.
Keep well
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
Guernsey70
« Reply #4 on: May 19, 2020, 22:47:01 »
Thank you Paul!!! Will try that too.  All the best.
Guernsey70
« Reply #5 on: May 20, 2020, 00:13:34 »
That solution worked Paul!😁. Thank you for the recommendation.    Cheers.
Paul & Dolly
  • i Car
« Reply #6 on: May 20, 2020, 06:20:46 »
Hi Ben
Glad it worked for you, an old but good trick..
Keep safe
Paul
Mitsubishi i Car
