Become a
Full Member
Emergency Contact List
Idle stalling
Topic: Idle stalling (Read 1744 times)
calicoup
Idle stalling
May 29, 2020, 16:59:02 »
Good morning, I recently had my late 250sl tuned and now after a cold start with engine idling at 8-900 rpm, rpms will drop and/or stall when accelerator pressed quickly. No problem if gently pushed or when warm or in gear.
Any thoughts? Thank you.
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Idle stalling
May 29, 2020, 18:46:33 »
Probably too lean or your distributor isn't working properly.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
1988 560SEC
Idle stalling
