Author Topic: Blistein Install  (Read 2439 times)
Harry
  • USA, TN, Knoxville
Blistein Install
« on: June 02, 2020, 01:51:23 »
I have a rattle when hitting some bumps and sinceI replaced the front shocks, I wonder if I might have not tightened them down enough.  What is the correct procedure,  please?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
specracer
  • USA, MA, Duxbury
Re: Blistein Install
« Reply #1 on: June 02, 2020, 09:39:49 »
What is the condition of your subframe mounts?
« Reply #2 on: June 02, 2020, 14:29:54 »
The upper nuts are tightened until the upper rubber compresses and the nut bottoms-out. Make sure one  rubber is above and one below the metal mounting. The lower rubber is under the rubber boot.  Double check the lower nuts are snug.
Harry
« Reply #3 on: June 02, 2020, 19:09:48 »
Sub-frame mounts also new.  I thought about whether I tightened those enough as well but I think so.  I'll check the nuts on the shocks but I don't remember any bottoming out.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #4 on: June 02, 2020, 22:59:42 »
Harry,
An experience that happened to me.
  I had some work on my car done and when i got it back i kept having this rattle in the front right going over rough road. Tried everything with the wheel, shocks and any other thing i could think about until one day on a hoist i. noticed the bracket on my radiator on RH side had broken and it could be rattled. Fixed problem.
Just something to check as it took me 6 months to find the problem.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Harry
« Reply #5 on: June 03, 2020, 19:17:53 »
I tightened the front shocks down until the nut "bottomed out", and this is the tightened position.  Does that look as should be expected?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #6 on: June 04, 2020, 03:59:17 »
Looks correct !
Harry
« Reply #7 on: June 04, 2020, 09:58:05 »
Thanks!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
yves
  • France, Poitou-Charentes
« Reply #8 on: June 04, 2020, 11:35:13 »
be careful when you close the bonnet it can be hit by the height of the shocks...
mbzse
« Reply #9 on: June 06, 2020, 12:45:19 »
Yes, perfect assembly.
From factory, there was a nut and counter locknut fitted. The Nyloc you used is perhaps more convenient
« Last Edit: June 20, 2020, 12:00:05 by mbzse »
/Hans S
« Reply #10 on: June 07, 2020, 01:42:17 »
Yes, the nyloc nut is what you get these days.
