Please check out joining the
Emergency Contact List
for help during your travels!
conection pipe
Topic: conection pipe (Read 1727 times)
bskladanek
conection pipe
June 03, 2020, 07:55:20 »
Hi there.
Let me help, i dont have idea what should be there (finger) and where should be conected.
Thanks guys!
bskladanek
Re: conection pipe
June 03, 2020, 07:56:23 »
PAGODA 250
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Re: conection pipe
Reply #2 on:
June 03, 2020, 08:25:13 »
looks like the connection of the vacuum line to brake booster.
...WRe
Full Member
Platinum
USA, OH, Blacklick
Re: conection pipe
Reply #3 on:
June 04, 2020, 04:01:59 »
It's the connection for the hydraulic constant idle speed cylinder from the power steering box. Some information in "The Linkage Tour" on this.
Last Edit: June 04, 2020, 04:09:03 by ja17
Associate Member
Platinum
Canada, ON, Port Lambton
Re: conection pipe
Reply #4 on:
June 04, 2020, 04:39:15 »
It moves the throttle linkage when you go to full lock on your steering. Not a common part on pagodas and more likely to see it on sedans or coupes.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
bskladanek
Re: conection pipe
Reply #5 on:
June 04, 2020, 13:07:40 »
thank you guys !!
conection pipe
