I believe this is the same bracket as yours, only mounted on the other side. I have LHD. On mine, I have the power window parts - (2) relays and terminal bock with fuses. You can see the voltage regulator mounted below that. Just to the rear is the auxiliary power box (with fuse) for the radio. That is the one with the silver knob.
The other view allows you to see the box better. You can also see one of the screw heads that hold the top plate to the bracket that is welded to the body.
I hope that helps.
