Author Topic: Sparkplug discontinued?  (Read 9923 times)
Re: Sparkplug discontinued?
« Reply #25 on: June 20, 2020, 05:09:36 »
Hello Wolfgang,
if you look closely under the column "S" it states "Firing End Construction", the fixed terminal nut is on the other end.
Since this NGK nomenclature is so confusing I inquired with the NGK Technical Support-USA why some BP5ES have a removable terminal and on others it is fixed. Here the reply:
"Thank you for your inquiry.
There are different terminal types for spark plugs. We no longer offer BP5ES in a loose design, the type where you can unscrew the tip, so the solid terminal type is normal for this plug. The loose design has superseded to the solid terminal type, stock number 7832 to stock number 2140.
 Please let me know if you have any additional questions."
I followed up by asking whether there is a decoder that would tell us which stock number for other plugs has the removable terminal nut but received no further replies.
Thus anyone searching for the correct BP5ES look for stock number 7832. Or perhaps for stock number 6511 as Paul noted earlier.
And if you search for BP6ES then find stock number 7333 and DO NOT buy the new stock number 7811, it has a fixed terminal.
Given that confusing state of part numbers it will be best to ask specifically whether the plug has a removable terminal nut.
« Last Edit: June 20, 2020, 05:19:33 by 66andBlue »
FGN59
  • France, Provence-Alpes-Côte d'Azur, Marseille
« Reply #26 on: June 20, 2020, 22:16:10 »
I recently purchased 2 sets of plugs on Amazon, one of BP5ES (6511) and the other BP6ES (7811). Both types have removable terminals screwed onto the external threaded part (lead?) that fits into the connector of our cars. Once The terminals are removed, they fit perfectly.
François
1994 Toyota Land Cruiser SW HDJ80 4.2L diesel
sold:
1969 280SL US specs, 4-speed manual, beige-grey (726H), parchment leather
1962 Jaguar MK2 3.8L (4.2L XJ6 engine), black, tan leather interior
1968 Peugeot 204 roadster, white, black interior
1955 Massey Ferguson TEF20 diesel tractor 😁
« Reply #27 on: June 21, 2020, 04:33:31 »
Good to know that you found a 7811 with a removable terminal nut.
This is another proof that NGK's numbering is out of wack.
Here are the details from another NGK information site (I added the coloring to highlight):
BP6ES - NGK Replacement Spark Plug Sparkplug - NEW No. 7811
Spanner Size : 20.8 mm (21mm)
Thread : M14
Thread Length : 19mm
Top Connection : FIXED top nut (Terminal Nut)
Spark Projection : 3mm
Nickel Centre Electrode
1 Single Earth Electrode
Non Resistor Type
Seat Type : Gasket Washer
« Reply #28 on: June 22, 2020, 15:42:04 »
Hmmm.
I stock both BP5ES and BP6ES in my "kit".
Stock #s 7832 and 7333 respectively. With removable tops.
My car runs better with the BP5ES, so that's what I just bought for a lifetime supply. I do have a new set of the BP6 as well.
alpina
  • Spain, Asturias, Villaviciosa
« Reply #29 on: June 22, 2020, 18:48:55 »
I  recently bought NGK BP5ES (6511) from Amazon here in Spain and they have removable tops.
Atazman
  • USA, Ca, Pleasanton
« Reply #30 on: June 23, 2020, 04:39:33 »
Who would have thought..........first toilet paper and now spark plugs!   ;D
I joined right in thinking it is time to change my BP6ES plugs for BP5ES.  Went to one of my favorite places (Rock Auto) and bought apparently their last "5" BP5ES for $0.81/each.  I know..... how much good will "5" spark plugs do me??  They arrived this past week.
Well.... I need  at least 1 more BP5ES plug, so ordered  from EBAY.  Also arrived this past week, only it is a BPR5ES plug.  I sent it back.
Still on the hunt for one more BP5ES.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
neelyrc
  • USA, AL, Birmingham
« Reply #31 on: June 23, 2020, 05:36:05 »
Try Advanced Auto Parts, physical stores, not on line.  A few days ago when I bought the last set of 6 from one store they had two single plugs still on the shelf.  Another of their stores I checked also had two only.  You might get lucky!
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
UJJ
  • USA, CA, Grass Valley
« Reply #32 on: June 23, 2020, 13:29:55 »
I just got 12 from Rock Auto for $1.48 each.
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
« Reply #33 on: June 24, 2020, 20:36:41 »
PM sent.
« Reply #35 on: June 24, 2020, 20:42:24 »
Still available on Amazon for about $3.00 each......
Both AlexD and myself tried this. They send the Resistor plugs!!!
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #36 on: June 24, 2020, 20:45:15 »
This happened to a friend of mine also.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
jeblack123
  • USA, GA, Albany
« Reply #37 on: June 24, 2020, 21:17:50 »
Thank you. I stand corrected......
« Reply #38 on: June 24, 2020, 22:37:02 »
I've had the same plugs in my car for over ten years and I've never had them out to even look at them. Once you get your ignition and fuel ratios set right pugs should last a long time. I've probably put 30,000 miles on the car in the last ten years.
1988 560SEC
Mike K
  • South Africa, Gauteng, Johannesburg
    • Mike Kirkinis
« Reply #39 on: June 26, 2020, 13:28:41 »
About a year ago I noticed that theses spark plugs were becoming increasingly difficult to find, both in France and South Africa. It didn't seem to make sense.
I had a sneaky feeling that at some point they were going to discontinue these plugs.  So I bought a dozen of the BP5ES for my 280SL Pagoda which lives in France and dozen of the  BP6EFS for my R107 300SL which lives in South Africa.
Based on Dan's numbers above that should be enough spark plugs to outlive me.....
« Last Edit: June 26, 2020, 13:49:21 by Mike K »
Feb. 1971 Mercedes 280SL Auto  LHD (Last of W113 Series)
Aug. 1989 Mercedes R107 300SL RHD (Last of R107 Series)
http://michali.zenfolio.com
http://www.lebombo-safaris.com
« Reply #40 on: June 26, 2020, 17:48:16 »
My guess is good old standby Bosch and Champion have non-resistor plugs that will work.
« Reply #41 on: June 26, 2020, 18:17:28 »
I won't use Champion spark plugs on an aluminum head engine. Both Bosch and NGK use nickel-plated shells which tend not to seize in aluminum. Use whatever you want but be careful with what you use.
1988 560SEC
« Reply #42 on: June 27, 2020, 18:59:56 »
Champion plugs today feature what they call "TinTac® and ULTRASEAL" and they claim "eliminates the need for use of anti-seize compound by providing the best corrosion protection of any spark plug"
I'm not here to sell them [Champion] or to test them; I have a lifetime supply of NGK.
If you ever screw anything in, that eventually must come out, particularly with dissimilar metals, I'm a fan of anti-seize. I generally use light coatings of "silver grade".
« Reply #43 on: June 28, 2020, 08:53:10 »
i just renewed my stock of W7DC and had no problem buying 100 of them from my usual supplier.
WRe
« Reply #44 on: June 28, 2020, 09:05:45 »
I second Dan's statement about Champion spark plugs. I've used them for years and 30.000km and had problems with my new NGKs because of "altered" threads. It was hard to screw the NGKs in.
...WRe
merrill
« Reply #45 on: June 29, 2020, 19:42:57 »
hello
NAPA has the NGK 7333 BP6ES on the shelf
Bosch W7DC are available from K&K and Authentic classics as well as other suppliers
I ended up buying 6 ngk from Napa and 12 w7dc from a vw supply house.
At the rate i drive i now have a lifetime supply of these plugs.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #46 on: June 30, 2020, 13:10:26 »
Merrill, it depends on where you are! Here in NC, they are about wiped out (NAPA) of the NGKs. One local place had none; another had 5. I ended up buying sets at O'Reilly and Advanced. Of course AlexD and his pals in the Raleigh-Durham area wiped out the NAPA supply...
...and like many others I now have 18 BP5ES "in stock", as well as a set of BP6ES.
col320ce
« Reply #47 on: July 01, 2020, 13:01:32 »
There are still plenty available in Australia ... if anyone needs pointing in the right direction let me know.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
WRe
« Reply #48 on: July 01, 2020, 14:44:23 »
in the meantime I believe that this story "to stop the production of non-resistor plugs" was launched by NGK to push their spark plug sales. ;-)
...WRe
« Reply #49 on: July 01, 2020, 15:43:30 »
...WRe
Haha. Remember, that all the plugs we've purchased, as far as NGK has been concerned, were already sold. Whether they sit on the shelf at NAPA or Advanced, or O'Reilly--doesn't matter. These retailers already bought and paid for them. We're just reducing inventory.
