Author Topic: Water Pump Maintenance?  (Read 1492 times)
McBenz
  • USA, TX, CELINA
  • Both car and owner from Stuttgart
« on: June 06, 2020, 20:57:37 »
Currently re-doing cooling system, replacing water pump and was wondering if any of the pulleys , as well as the water pump need any lubrication, grease etc.? I saw in a MB parts catalog that the 3 hole water pumps came in maintenance and maintenance-free versions, while the (4) hole, including mine had only one option. I'm guessing that the later (4) hole ones were maintenance-free going forward. But, while I have the belts off and radiator removed, I would better check with you guys if there is any particular lubrication recommended. Thanks. Mark.
1965 230 SL (Family Owned Since June 1965)
1974 Porsche 914 2.0L
2000 LX470 100 Series LandCruiser
Re: Water Pump Maintenance?
« Reply #1 on: June 06, 2020, 21:46:32 »
The "maintenance style" water pumps have two removable screw plugs. The one on the top is so you can add 90w oil. The one on the side is the fill level. If your water pump does not have the plugs it is maintenance free.
McBenz
  • USA, TX, CELINA
« Reply #2 on: June 08, 2020, 02:01:29 »
Cool, thank you.
