Author Topic: King pin reamer  (Read 1551 times)
230slhouston
King pin reamer
« on: June 08, 2020, 02:00:39 »
Can someone please let me know what size reamer I need to ream  the king pin bushes.
A part number or where to buy will be appreciated. Not too expensive. Single use in my case.
Maistran.
twistedtree
  • USA, MA, Gloucester
Re: King pin reamer
« Reply #1 on: June 08, 2020, 11:02:02 »
When I did mine I bought this adjustable reamer for a whopping $11.  I see now it's $12.  It worked great, and I like having it adjustable so you can creep up on the correct size, checking the fit as you go.  Just be careful you don't over cut.
https://www.wttool.com/index/page/product/product_id/35520/category_id/14710/product_name/RDX+Adjustable+Blade+Hand+Reamers
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
230slhouston
Re: King pin reamer
« Reply #2 on: June 08, 2020, 16:16:12 »
Peter,
Thanks.
How long are the cutting blades? Does it have to be long enough to ream both bushes at the same time?
Maistran.
twistedtree
Re: King pin reamer
« Reply #3 on: June 08, 2020, 17:20:31 »
Just checked it and the blades are 2.5" (~65mm) long, so one bushing at a time.  It's been a number of years since I used it, but my recollection is that it was no big deal to get a good fit, with not a lot of material removed.  Just start out with a real light cut and progress slowly.  It would really suck to over cut it.
« Last Edit: June 09, 2020, 10:46:46 by twistedtree »
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Re: King pin reamer
« Reply #4 on: June 09, 2020, 09:58:16 »
You need a reamer that will be long enough to ensure both bushes are cut in the same axis. Mine has a centralising element.
If you cut each bush individually you will not be assured of correct alignment.
