Author Topic: Positive battery cable  (Read 3183 times)
badali
  • USA, Pa, Butler
  • 1966 230SL
« on: June 21, 2020, 22:49:25 »
I'm looking for the positive battery cable and I think the part number is 113 540 01 30. (1966 230SL) I checked the classic center parts search and it did not come up as available.  Is it available on any other parts sites?
Brad
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Vander
  • USA, OH, Columbus
Re: Positive battery cable
« Reply #1 on: June 21, 2020, 22:52:39 »
I needed one recently and I found the best option was to make one, it was better quality than the options that were readily available.
mnahon
  • Canada, QC, Montreal
« Reply #2 on: June 22, 2020, 00:27:51 »
I bought one recently from SLS in Germany; it seemed well made. The installation went smoothly apart from the fact that it's a bit hard to get it snaked through all the various clamps.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
winston the browndog
« Reply #3 on: June 22, 2020, 02:47:46 »
Rhode Island Wiring Service custom makes them to order. They are listed on the parts provider list .
  • USA, WI, Mequon
« Reply #4 on: June 22, 2020, 13:57:29 »
Make one from www.batterycableusa.com  They are great.  Pick you gauge, terminals, covers, etc.  I had a couple made for a different car to replace the crappy ones on there, beautiful!
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #5 on: June 22, 2020, 15:11:17 »
Does anyone know the length of the cable before I remove it?  I hate to disable the car and would prefer to have a new one ready to install.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #6 on: June 22, 2020, 16:37:29 »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #7 on: June 22, 2020, 16:42:23 »
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
« Reply #8 on: June 22, 2020, 16:54:49 »
As per SLS there are longer ones, for later cars, 157cm and shorter ones for 230SL, 147cm.
https://www.sls-hh-shop.de/main/en/54-elektrical-equipment-at-body-54equipment-for-cable-harness-c-3_2339_83
I ordered the longer one for 280SL and it fit ok. Always better to have longer than shorter...
If you are buying the wire to make it yourself, I noticed it is quite important the it is made of thin threads so that even though it is a thick piece of wire, it is soft and easy to shape.
specracer
  • USA, MA, Duxbury
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #10 on: June 23, 2020, 00:35:01 »
There is one here:
https://www.authenticclassics.com/Positive-Battery-Cable-to-Starter-fits-108-p/auth-007835.htm
That looks like what I need.  Thanks,  I verify that it is long enough since it says it will fit.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
