Author Topic: W113 Throttle positionb switch  (Read 2324 times)
Yooks
« on: June 27, 2020, 18:18:04 »
Hi all, need advice. Im in need of a throttle position switch which lives on the side of the throttle housing. I have located one but the seller cannot confirm it is compatible for my 230SL. Are the switches interchangeable fro 230,250 and 280? Or correct part number for W113 230SL 1964 Manual would be appreciated too. Thanks
Re: W113 Throttle positionb switch
« Reply #1 on: June 27, 2020, 20:02:41 »
For 113042
Switch A 000 545 24 04 replaced with
A 000 545 33 04 As of engine: 981 10/50,20/60 010787 - 014471 981 12/52,22/62 002991 - 005668
For 113043
A 000 545 33 04
For 113044
A 000 545 33 04 Up to engine: 980 12/52 021165 980 22/62 020980 981 12/52 001686 981 22/62 001630 984 000098
I spotted one in a friend's car - fintail with this big V8, but in manual. I think it fits from more MB cars with this throttle body.
« Reply #2 on: June 28, 2020, 15:58:00 »
Yes they are the same. Also, you can open them up and clean the contacts if your old one is bad.
