Author Topic: Correct Fan Bolt Size- Fan Clutch to Pulley  (Read 1534 times)
McBenz
  • USA, TX, CELINA
  • Both car and owner from Stuttgart
« on: June 27, 2020, 19:25:13 »
I'm trying to figure out the correct bolt size and length of the (4) bolts that hold the fan/fan clutch to the water pump pulley on 1965 230sl. I saw on a video from Kent at Mercedessource (YouTube) that some cars have incorrect length bolts that make it very difficult to get the bolts mounted and tightened due to their too long length. Does anyone know the correct size for those (4) bolts. Mine seem quite long at 40 mm. Are there shorter ones required? Thanks.
1965 230 SL (Family Owned Since June 1965)
1974 Porsche 914 2.0L
2000 LX470 100 Series LandCruiser
WRe
Re: Correct Fan Bolt Size- Fan Clutch to Pulley
« Reply #1 on: June 27, 2020, 19:50:03 »
4 shouldered/collar screws M8x16 wrench size 10 which is not standard (ws 13) and the main problem because it causes round heads.
...WRe
« Last Edit: June 27, 2020, 19:54:42 by WRe »
mnahon
  • Canada, QC, Montreal
« Reply #2 on: June 27, 2020, 22:44:03 »
When I did this job, I ended up finding this bolt from a motorcycle application. Apico p/n 024-20816 has all the right specs. I'm not sure whether the length of these bolts may depend on whether you use the long pump or the short pump plus spacer.
See this thread:
https://www.sl113.org/forums/index.php?topic=21078.msg149943#msg149943
« Last Edit: June 27, 2020, 22:49:22 by mnahon »
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
WRe
« Reply #3 on: June 28, 2020, 07:27:09 »
MB part number is A1149900010, current price 6,16€.
I ended up with the standard screw (ws13) but found it with ws10 in motorbike shops too (KTM).
...WRe
