Author Topic: I did it again ... this time it's a 1972 Lancia Fulvia Coupe  (Read 57116 times)
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: I did it again ... this time it's a 1972 Lancia Fulvia Coupe
« Reply #50 on: November 22, 2021, 17:29:57 »
Awesome work - I am jealous that you have the time to play.   I admire the work you have done.  Well done.
Back when I had just got out of University and went and got married (early 90's) a buddy of mine had a neighbor with a back yard full of Italian cars.  The neighbor had passed away and the widow asked my buddy and his bother if he or his friends would like any of the cars before she had them towed away.
There was a Lancia Fulvia in need of rust repairs,  a relatively new 4wd Lancia Delta that rolled and was missing the windows (but had a roll cage) and a pristine Alfa Guilia (4 door).   All free for the taking.    Damn I wish I had storage space then.   The Alfa ended up sitting in his parents back yard for 4-5 years and finally he gave it away.    I don't know why but I wasn't interested in any of them at the time.   Fast forward 30 years and what would I give for any of them.    Especially that 4wd Delta.  I'm sure I could have straightened it out / painted it white with a few stripes.....
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
« Reply #51 on: November 25, 2021, 01:20:04 »
Yes Ian, we probably all have memories of cars now very desirable that we could have bought way back when. I had a Alfa GTV 1750, my very first car, that I bought for the princely sum of $250 when it was less than 10 years old (already leaked a lot of oil though).
Well I just spray painted the shell - armed with more tips from a member of the Lancia forums and my extensive experience, having painted the Volkswagen 411 earlier this year and then the various Fulvia parts where I made a few mistakes, I managed somehow to avoid those and I am looking at an almost perfect paint job 'straight out of the gun' now curing slowly. I ended up using the entire 5 quarts of Tractor Red paint on this little car, so it's definitely enough. I have just a few small runs but those I should be able to remove relatively easily. I have 3M's 'one-step' system for wetsanding and polishing on the way, so after some more elbow grease I expect to have a really, really nice result. All in all in materials (paint, primer, reducers, sandpaper, masking paper and tape) I spent about $500:
« Reply #52 on: November 25, 2021, 02:31:05 »
Great job Cees. Nice colour.
 I just love that model of the Lancia.
« Reply #53 on: December 19, 2021, 20:54:13 »
Since the paint went on I've enjoyed the 'cleaner' jobs of installing many new parts, mainly all light fixtures, grill and various other assorted bits. Also got the  front and rear winscreens back in place and dismantled the entire engine. I checked and measured everything against the technical data specifictations and earlier this week ordered all the engine parts I need from a supplier in France - they are on their way. It does not need much: new valves/springs/guides, connecting rod bearings, oil pump, piston rings but the pistons themselves, still standard spec, are in great shape and so are the bores, the crankshaft and the main bearings. Also installed all the trim, the rear side windows and window seals. I did have 3 head bolts shear off and had to get those drilled out by a specialized machine shop.
It's coming along well, I have still a lot of jobs to do but there is light at the end of the tunnel for sure. Getting the paint on so well was a big milestone.
Also had the magnesium wheels straigthened and powdercoated. One of the photos is just to get an idea of what it will look like once done.
« Reply #54 on: December 19, 2021, 20:58:25 »
Some more pics:
« Reply #55 on: December 19, 2021, 23:11:04 »
Absolutely awesome, Cees!
DaveB
« Reply #56 on: December 20, 2021, 06:13:45 »
That's high-quality work on a neat-looking car. I like the faux woodgrain dash!
DaveB
'65 US 230sl 4-speed, DB190
« Reply #57 on: February 24, 2022, 03:51:20 »
Picking up the engine rebuild parts tomorrow. Meanwhile have been addressing the many smaller jobs that need doing, like removing surface rust off the many suspension components and then repainting in 2K satin black, fitting new bushings, ball joints, CV axle boots and so on. Refitting the doors and the door-related mechanisms, locks etc. This coming weekend I hope to pass a milestone, which is to get the car back on its wheels - fitting the rear axle, springs, shocks, brakes etc etc, many components new:
Pinder
  • USA, NJ, Edison
« Reply #58 on: February 25, 2022, 00:48:12 »
Cees you mentioned tracker paint. what type of paint system is that. is it enamel or single Stage AU ? does it need any catalyst? Really nice work you do.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #59 on: February 25, 2022, 03:12:52 »
Thanks Pinder!
The paint I used for my 4 cars is single-stage urethane from TCP Global. I get the gallon-kit which comes with an additional quart of hardener - so the mix ratio is 4:1. I usually add reducer, around 10-15%.
Here's their webpage. There's other suppliers out there but I have been very pleased with this paint:
https://tcpglobal.com/pages/acrylic-urethane-paint
Pinder
  • USA, NJ, Edison
« Reply #60 on: February 26, 2022, 01:07:56 »
Nice.  get it from them too.  I like the fact I can order online.
« Reply #61 on: April 28, 2022, 16:26:28 »
The engine is back together, timed, with the head totally redone and everything else that was needed, including new piston rings. Plastigauged the bearings, measured the combustion chambers, the works.
Hopefully today the whole sub-frame assembly with the engine is going back into the car. On the home stretch:
« Reply #62 on: April 29, 2022, 09:16:51 »
Looking really good...
« Reply #63 on: May 09, 2022, 02:02:25 »
Thanks Peter/
Much progress to report - had it not been for a defective fuel pump, I could have had the engine running for the first time since the rebuild yesterday. New pump on the way ($55 plus shipping from Atlanta) and today I wrapped up the electricals (all of the lights, fuel gauge, fan, warning lights, interior lights - so many electricals on a car!). Had to troubleshoot here and there, fix grounds, install new bulbs and so on, but now everything works. Even the clock, that was not running when I got the car so I opened it up, cleaned and oiled it and so on, seems to be keeping good time now. Over the past few days I installed all new coolant hoses and fuel lines. Still some more work to go but it's almost there. Fingers crossed on that first start-up ...
DaveB
« Reply #64 on: May 09, 2022, 02:57:17 »
I see you got what I presume is a factory-correct body colour overspray on the underside, like the pagoda.
It would be great if you can film your startup, I'm sure it'll sound good. And will be a very engaging driving experience.
You might be sad to see it go, but you'll have a good profit as recompense.
DaveB
« Reply #65 on: May 30, 2022, 00:08:31 »
Well heading for a bit of an anti-climactic pause to this adventure. We are moving back onto our boat at the end of June so I am losing my workspace/garage, and the Lancia is almost, but not quite, finished. I first ran into weeks of delay on the carburetors that were not functioning properly, so I had to rebuild them, get an ultrasonic cleaner for them, and so on. But once I sorted that out, the engine was not building oil pressure. So now I am looking into the cause of that - must be something really simple, but in any event it is looking exceedingly unlikely I will get that sorted in time to have the car inspected and titled/registered by DMV here in California. So yesterday I rented a garage in Santa Monica where I will store it until I can locate a new workspace (a friend and I are looking for one to start restoring cars for fun, around Culver City/Inglewood.
Meanwhile here a video of me cranking the engine and trying to prime the oil pump:
https://www.youtube.com/watch?v=97ysYKjmCC8
Today I finished the second-to-last job on the car, installing the passenger side window regulator, window, doorcard and related hardware. Only thing left now is the front brake lines and hoses. Then off to the slumber lounge in Santa Monica ...
neelyrc
  • USA, AL, Birmingham
« Reply #66 on: July 24, 2022, 15:25:01 »
Cees,
Today the Mare-Monte Rally for pre 1991 cars and motorcycles was held here in Italy. The Rally runs from Chiavari on the sea to Bedonia in the Apennines near my home.  We watched the participants arrive and had the opportunity to look over the vehicles later.  There were two Lancia Fulvia coupes participating.  I only got a a picture of one, a 1968 model.
Unfortunately there were no Pagoda participants, Mercedes being represented by a single 190SL and two 107s.
Enjoy!
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
« Reply #67 on: July 24, 2022, 18:27:19 »
Very nice Ralph, thamks for posting. Lovely Series 1 and in a nice color also.
Pinder
  • USA, NJ, Edison
« Reply #68 on: July 25, 2022, 13:31:38 »
Really amazing quality of work.
« Reply #69 on: March 16, 2023, 03:51:19 »
Short update on the Lancia restoration - Saturday a week ago I moved the car to my new workshop/garage, where I am restoring the '61 Alfa Romeo Giulietta Sprint, in order to address the remaining couple of issues. The two most important ones being that the brake master cylinder was not building pressure despite me having fitted new seals (= bad), and no oil pressure on starting up the rebuilt engine (= also bad). It turned out the root cause was similar - both pumps had to be primed in a specific manner.
As for the brake cylinder, I took it all apart again, cleaned it with brake cleaner and then reassembled but with plenty of brake fluid inside the bore and on all the seals. Then bench bleeding, and this time it started to work. Installed it on the car, bled each of the four corners and ended up with a nice firm pedal. Job 1 done.
Turning to the oil pressure situation, I first disassembled the oil pump. This is mounted inside a housing at the front of the engine and it can be removed by jacking up the engine a few inches (of course, this requires removing two of the three engine / transmission mounts and some other items). To my surprise, the pump was bone dry - no oil whatsoever. I then dropped the oil pan to see if the pickup was properly sealed against the bottom of the engine block (or the pump would be sucking up air), but that was all good. Following a tip from who I bought the Lancia (as well as the Alfa) from (and the owner of the garage/workshop) I poured oil into a fitting on top of the engine that, according to the workshop manual, routes straight into the pressure side of the oil pump. After verifying that indeed the oil was reaching the pump, so there was no obstruction inside the engine that could cause problems, I poured in about a quart of oil, then filled the crankcase until the dipstick showed 'full'. This afternoon, after installing a new torque starter (1.8 HP) to replace the rather worn out original Bosch unit (0.8 HP) I hooked up an oil pressure test gauge to the engine and after some cranking the gauge returned a very healthy 35 PSI of pressure. I could also see plenty of oil was making it to the top of the engine, on the camshafts etc.
So now that the two most important remaining issues have been resolved, it's onto a few minor remaining niggles, putting in fresh fuel and starting to enjoy!
When I get to that stage (still need to finalize the California registration process) I will take some more pictures and post some driving videos. Can't wait, the entire restoration has taken about 18 months if I don't count the '21 and '22 summers we spent in France.
« Reply #70 on: March 23, 2023, 19:00:57 »
First start yesterday, today hopefully finetuning the carburetors (synchronizing/idle/mixture). First 'drive' was out of the garage, reverse back into it with the tail pipe out the door so we can tune it withoug suffocating:
https://www.youtube.com/watch?v=j5li5QDjABg
Almost done. New seat belts on the way from Germany.
kampala
  • USA, CA, Hermosa Beach
« Reply #71 on: March 24, 2023, 14:21:38 »
Motor sounds great on the YouTube link.  Nice.
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #72 on: April 02, 2023, 01:06:10 »
Thanks Kampala!
More fiddling this week with the carburetors, it's been a very long time since I had to deal with that technology. It turns out the new intake manifold came without a necessary notch for the throttle linkage, preventing the butterflies from closing sufficiently. I corrected that and this afternoon re-synced the two carbs, set the 4 individual mixture screws and the overall idle. Now the engine runs very smooth and revs happily:
https://www.youtube.com/watch?v=-VO-d0JxJt8&t=13s
« Reply #73 on: April 15, 2023, 02:08:49 »
Finally got the car inspected by the local DMV and CHP (California Highway Patrol) - since it carried a New Jersey title, with an incorrect VIN to boot (transposition error: 818.360 instead of 818.630) it had to go through a lot of scrutiny. But, this afternoon, I received registration and license plates, so now it's off to the races, I can finally start enjoying! I've covered about 80 km driving to and from the DMV and CHP on one-day operating permits and through it all, negotiating Los Angeles traffic, it's been driving great, pulling strong, shifting well, braking well, keeping good coolant temperature and absorbing the road bumps. All in all a joy to drive. It does need a front-end alignment, since I had it all apart and replaced most of the suspension and steering components but once that is done I will look for some of those famous canyons around LA ...
Now I can re-focus my attention on the '61 Giulietta Sprint.
« Reply #74 on: April 18, 2023, 18:47:32 »
https://media.giphy.com/media/VIfE4DE7vY49i/giphy.gif
