Author Topic: 230SL Throttle Linkage Dismantling  (Read 1871 times)
mistertj
  • USA, FL, Satellite Beach
« on: July 15, 2020, 13:12:54 »
Does the throttle linkage shaft just pull out of the socket? I have pulled pretty hard and it does not want to budge. I don't want to break anything. Any tricks to getting it apart?
WRe
Re: 230SL Throttle Linkage Dismantling
« Reply #1 on: July 15, 2020, 14:22:39 »
you have to press it out, a little circlip holds it in place: https://www.sl113.org/forums/index.php?topic=898.
...WRe
« Reply #2 on: July 15, 2020, 14:56:52 »
Might also try to put some light oil or penetrant on the ball in case there is none. That will help it pull out easier.
mistertj
« Reply #3 on: July 15, 2020, 15:11:03 »
Think I'll just leave it alone and paint it out of the car but while assembled. It ain't broke...just want to make it look pretty. :)
« Reply #4 on: July 16, 2020, 06:16:59 »
It will pop out of the socket with the brass bushing. However you can remove the "C" clip,which leaves the brass ball bushing in place and also remove the linkage rod.
« Reply #5 on: July 17, 2020, 10:22:01 »
Disconnect all the rods and the mounting bracket on the left side of the engine.
Then give it a strong pull. It should snap out.
mbzse
« Reply #6 on: July 17, 2020, 13:29:20 »
One can tap the cross bar sideways gently, with a plastic mallet
/Hans S
« Reply #7 on: July 17, 2020, 18:26:49 »
This is a similar socket design in theory to the smaller throttle linkage sockets. It is just bigger and requires more force to pop out.
