Author Topic: What is the difference between 1970 280SL early and late model?  (Read 2395 times)
CJHenderson
  • USA, AR, Benton
What is the difference between 1970 280SL early and late model? Needing to order the exhaust system and other items.
1950 MG-TD
MikeSimon
  • USA, OH, North Royalton
Re: What is the difference between 1970 280SL early and late model?
« Reply #1 on: July 20, 2020, 17:55:49 »
I think "early" and "late" are too general of terms to answer this. Most changes were engine related - cylinder head, e.g. - and you have to look at engine serial number to determine when what changes took place
It also depends whether it is a manual or automatic and what country spec the car originally is. For the exhaust, I believe, you should be OK. No change that affected this. Other parts, you need to look at one by one.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
TJMart
  • USA, NC, Matthews
« Reply #2 on: July 20, 2020, 18:30:17 »
You may want to look at "Pagoda World" Issue #25 September 2019. It has an excellent article for the Changes made to the 280SL by VIN and Date. This may help you on specific changes made.
Tony
1970 280SL, 4 Speed
GM
  • USA, CA, San Pedro
« Reply #3 on: July 20, 2020, 19:07:24 »
Also in the Tech Manual, in Pagoda Notes - Volume II, No.1, January 2017
https://www.sl113.org/wiki/uploads/Restricted/PNv11i1.pdf
Continues in Volume II, No.2
« Last Edit: July 20, 2020, 21:16:45 by GM »
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
scoot
  • USA, CA, Altadena
« Reply #4 on: July 20, 2020, 19:52:58 »
You may be thinking of the difference between a early and late 250SL...   Early has the interior of a 230 SL, late has the interior of a 280 SL.
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #5 on: July 23, 2020, 16:39:57 »
There is a major bresk in the 280 run where the changed cylinder head and emission control on the US model.  Simply if you have a small steel oil fill cap and not a cast aluminum one you have a later engine.  Another way to double check is if you have 2 Blackbrelay boxes behind the battery a foot or so.
