I'm doing new shifter linkage bushings on my automatic. I need a picture of the assembly. I have got it apart and neglected to take a photo and I need to know the correct assembly particularly of the aluminum casting of the lever and the spring and pins. The aluminum casting has to be installed correctly as it has to bolt on to the tunnel in a particular direction. I have all the new bushings and I took the assembly out from inside the car, I just unlooked the rod at the transmission then pulled everything out from the tunnel inside. Hope this description helps. Thanks, Carey Underhill. Travellerdogs.
