Author Topic: UPDATED Misc. Items for Sale  (Read 3824 times)
Kamihome@btcpc.com
  • USA, IL, Kildeer
« on: July 28, 2020, 15:44:24 »
Hi All,
Many of the items I had listed are spoken for....thank you for the responses.  Unfortunately, it has become a headache to respond to all the requests for free items and ship various items to folks.  Therefore, I will no longer be shipping only the free items.  If you purchase some of my for sale items, let me know what you need and if I have it, I will be happy to send it free of charge.
Item for sale (New parts are after market unless I indicated MB brand - I have indicated my asking price), add shipping cost.
SOLD _ Pair of Used seat cross bars with tilt handles, these are the polished aluminum bars behind the seats with a lever to tilt the seats forward, in good condition, $70
Sold - New VDO Washer pump, $40
NOS Bosch Regulator in original box, has some surface oxidation, $75
SOLD - Grill, right side wing, new, after market, $50
250 SL Trunk Emblem - $75
SOLD - Original used interior light with simulated chrome surround, good condition, but the chrome is not perfect, $30
Sold - New left side MB brand tail light frame in box - $100
Late flasher switch, new but does not have knob, $40
Alternator adjusting arm, new short style, includes hardware, $20
Alternator adjusting, long, new, includes hardware, $20
Sold - New right side MB Brand tail light frame in box (but I previously tried to glue the lens to it, so it has glue remnants - $75
SOLD - New engine mounts, pair, $50
Items available free of charge if you purchase other items:
Rear axle cross strut rubber bushing One only, new
GONE - Injection pump thermal isolation ship and one gasket, new
GONE - Rear Control arm bushing set, new
GONE - Steering column to fire wall gasket, used
GONE - Euro headlight gaskets, new
Gone - Fuel line from pump to feed line, new
Gone - Door handle pad, only one set
GONE - Set of new rear axle bearings and seals, open box, missing a gasket and a lock plate
Early blower switch, new, no knob, not very good quality
GONE - Hood release interior grab handle (used but in good condition)
GONE - Crankshaft Necked bolt and dished washer, new
Gone - Right side auto transmission line, new
Gone - Small bypass water line from water pump to thermostat (c shaped hard line with banjo fittings on both ends), new
Gone - L-shaped Water hard line from Thermostat to rubber hose leading to throttle body (has banjo fitting on one end), new
GONE - A few side molding clips, new
GONE - Several soft top shims, new
GONE - Several top handle shims, new
Used cigarette lighter and socket, do not know if the lighter works
Thermostat housing, used, but in good condition
GONE - Original type AC bracket idler pully fastening screw and bracket
Gone - New coil bracket
Gone - New parking brake cable, from handle to the bracket below floor
Gone - Water outlet which screws into side of block on drivers side, feeds oil cooler on 250SL, new
Set of new con rod bolts, SLS Part no. 103075...these were too small for my con rods, so not sure what they fit!
GONE - Two used soft top rear bow springs (these are the two smaller torsion springs, not the large tension springs)
Please see separate listings for new wiring harness, brake booster, used oil pump, used cam, door glass, and radiator.
Prices are excluding shipping.  Payment will only be via PayPal.
Thank you
« Last Edit: August 27, 2020, 01:39:45 by Kamihome@btcpc.com »
mBdrvr
  • USA, PA, Bethlehem
Re: Misc. Items, Free for Members or Make Offer
« Reply #1 on: July 28, 2020, 16:13:18 »
I sent you a private message (PM)
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Kamihome@btcpc.com
  • USA, IL, Kildeer
« Reply #2 on: July 28, 2020, 16:37:04 »
Thank you for the overwhelming response.  I will continue to add items as I run across them.  Following are additional items for sale subject to a reasonable offer:
Bosch AL72x alternator, rebuilt (this is the 55-amp direct replacement for the original 35-amp version with the same 3-pole plug and external regulator)
Tool bag and tools (purchased new from Mercedes classic center, has a blue canvas bag, but it is not the same as original)
  • USA
« Reply #3 on: July 28, 2020, 19:03:25 »
Hello Kamil,
Sent you a PM as well.
« Reply #4 on: July 29, 2020, 00:17:03 »
A PM has been sent re pricing.  Please correct to the For Sale requirements.
« Last Edit: August 16, 2020, 22:09:39 by Garry »
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
pagoden
  • USA, MD, Silver Spring
Re: Misc. Items, $0.10 for Members, and Others for Sale
« Reply #5 on: August 13, 2020, 02:04:50 »
Hi; I tried PM but it resisted best efforts, outlasted me through a coupla days of off-&-on trying. sooo........
Wish to purchase the (4) rubber (rear) spring mounts, and the crank bolt with washer.
Also the (2) door seals, $90.
I fully understand your request for it, but someone (maybe one of my offspring) may well need to walk me through sending you a mailing label,
but I can get you $100US anytime through painless Paypal.
Denny
mBdrvr
« Reply #6 on: August 13, 2020, 17:39:15 »
I just saw your reply to my private message.
Is the interior light still available?
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
ricSL
Re: UPDATED Misc. Items, $0.10 for Members, and Others for Sale
« Reply #7 on: August 16, 2020, 12:32:24 »
Hello, I just happened to read this post and I see there is many items I could use and since your offer to allow members to come by for a look see I  would like to come by, I'm free most any day and time so just give me a time and day good for you.
Best regards, Richard Kawashima.
973 W 37th Pl, (Bridgeport area) 775 830-3304 cell
