Become a
Full Member
Emergency Contact List
Rear Spring Rubber mounts
Topic: Rear Spring Rubber mounts (Read 1465 times)
230slhouston
July 31, 2020, 02:01:13 »
I am restoring my differential and have a question on the spring rubber mounts. I managed to get the part number of the upper mount. It is 110-325-04-85 and I did read thread
https://www.sl113.org/forums/index.php?topic=5852.0
where this is discussed and my part number is 18mm.
I cannot find part my part number for sale but the thread references part number 108 325 0385 18mm. Is this the alternate part number to use? it is available.
Also, I do not have the lower part number. KKMFG lists this as 108-325-03-85. Is it the same number for all models?
My car is a 66 230sl.
Thanks.
Maistran.
Full Member
Platinum
USA, OH, Blacklick
Re: Rear Spring Rubber mounts
July 31, 2020, 05:15:42 »
Yes the rear lower is the same for most of the models in that era.
230slhouston
Reply #2 on:
August 01, 2020, 17:11:05 »
Thanks Joe. I ordered from Mercedes. will post pictures as I go.
Maistran
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
August 01, 2020, 17:54:43 »
The bottom ones, like to work themselves out of place over time. I use some weather strip adhesive and glue them to the metal base to make sure they stay in place.
