Author Topic: Rear View Mirror Glass Gasket  (Read 4671 times)
m300cab
  • USA, Pennington New Jersey
« on: August 04, 2020, 00:46:03 »
Hello all, I'm working on a 1963 rear view mirror. I had it re-chromed.
Now I need the gasket that goes around the actual  mirror.
I can't seem to find a source.  I may use almond colored window sealer from a tube.
Thank you
Michael Parlato
Desertpagoda
  • USA, AZ, Tucson
Re: Rear View Mirror Glass Gasket
« Reply #1 on: August 07, 2020, 00:07:54 »
Not avail from the dealer? I have bought the trapezoidal glass and retainer drom MB within the last 45 days? kb
kb
« Reply #2 on: August 07, 2020, 00:16:19 »
Thank you
Which rear view mirror, outside or inside?
WRe
« Last Edit: August 07, 2020, 06:35:05 by WRe »
« Reply #4 on: August 07, 2020, 14:05:46 »
It is available at the dealers.
For goose neck, up to ident. no.: 043 002979, it is A 000 811 01 65 for about $12.
Later one, A 108 811 00 65 for about $25.
Quality is important, I would buy from the dealers.
For the central rear view mirror, the one inside, there is no gasket as a separate part, the mirror came as a whole.
m300cab
« Reply #5 on: August 07, 2020, 20:29:27 »
IT'S The inside mirror.  The Classic Center could Not Help
Michael Parlato
« Reply #6 on: August 08, 2020, 09:31:21 »
There is no such part on the parts list. Inside mirror comes as one piece as a spare part.
m300cab
« Reply #7 on: August 08, 2020, 16:42:39 »
great, thank you.
I purchased bisque caulk in a tube. going to replicate the gasket.
Michael Parlato
acbrock
  • USA, CA, Santa Monica
« Reply #8 on: May 03, 2024, 17:26:26 »
I know this thread is long dead but just in case someone found another option. I am looking for the the Gasket for the Inside Rear View Mirror.  Seems crazy that would have have to purchase a whole new mirror just for that one Gasket?  I will keep searching.
1966 230SL Automatic 717G Papyrus White "Minny"
BobH
« Reply #9 on: May 03, 2024, 18:50:19 »
I took my mirror apart to have the glass re-silvered, and i didn't take much notice of the gasket, if you measure it, can you not buy a length from a supplier of silicon, rubber or plastic profiles?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
m300cab
« Reply #10 on: May 05, 2024, 17:41:02 »
I purchased almond caulk for mine.
I have not actually finished the project.
my plan is to use the caulk as the gasket.
Michael Parlato
« Reply #11 on: May 06, 2024, 17:44:26 »
I use good old fashioned glazing putty.
