Author Topic: W11x What goes here?  (Read 2480 times)
col320ce
« on: August 07, 2020, 14:13:25 »
There are 2 square holes on the 250SE/cp firewall.... What is supposed to be there??
Thanks!
« Last Edit: August 07, 2020, 14:18:53 by col320ce »
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
col320ce
Re: What goes here?
« Reply #1 on: August 07, 2020, 14:16:53 »
Pic
Col
1964 230SL
1965 250SE coupe
Re: W11x What goes here?
« Reply #2 on: August 07, 2020, 15:40:51 »
I thought I knew but just checked to be sure. Those are the mounting holes for the throttle rod bracket as it goes across the firewall. Since you drive on the wrong side ( ;D), not sure you use these and might have square rubber plugs in place of that. I do not have an unused pair of square holes on mine, but the firewall pad would cover them up.
col320ce
« Reply #3 on: August 08, 2020, 02:51:22 »
Thanks!
I'll try to find some grommets to fill them up.
Col
1964 230SL
1965 250SE coupe
