Author Topic: Checking oil pump for wear  (Read 1886 times)
doitwright
  • USA, IL, Willowbrook
« on: August 10, 2020, 11:19:00 »
I purchased what was described as a NOS oil pump. Now that I have received it. I am questioning if it is new or worn out. Should There be any back and forth play in the gears? I demonstrate what I am talking about in this video.
https://drive.google.com/file/d/1Uegm-MRs9gWTV7b-6MCdy5fAmg6LxXMN/view?usp=drivesdk
Frank Koronkiewicz
Willowbrook, Illinois
mbzse
Re: Checking oil pump for wear
« Reply #1 on: August 10, 2020, 16:41:28 »
Quote from: doitwright
.../...oil pump. Now that I have received it. I am questioning if it is new or worn out. Should There be any back and forth play in the gears?.../...
There are specifications in the workshop manual (BBB).
See attached. One can use blade or pin feeler gauges, micrometer etc in order to evaluate status of a used engine oil pump.
/Hans S
doitwright
« Reply #2 on: August 10, 2020, 17:24:02 »
The question is: Is backlash normal for a new pump?
Frank Koronkiewicz
« Reply #3 on: August 11, 2020, 04:25:17 »
Yes, you would need a little bit to keep it from binding. Radial play or backlash is in the .002 - .003" range so it's not very much.
doitwright
« Reply #4 on: August 14, 2020, 05:17:44 »
Thank you Hans and Dan for the information. It looks like the pump is a keeper.
Frank Koronkiewicz
