Make yourself a little puller. Find a very large nut with an opening big enough for the pin to slide through. Next find some washers and a bolt that threads into the pin. Place the nut over the opening, add washers to the opposite side and thread the bolt into the threaded pin. When you tighten the bolt the pin will be pulled out of the head through the large nut. You may have to stop once or twice to add more washers as you run out of threads.
Thank you,
Maybe I wasn’t clear enough, but I’ve done that.
I get the feeling like something is still preventing the movement of the pin.
I’ll spray some more penetrating fluid and try again.
We are talking about fairly light forces here, correct? No heavy duty tools 💪
