Author Topic: Hasn't run in 24 years  (Read 1301 times)
jklcycles
« on: August 14, 2020, 00:43:34 »
My 1966 230SL hasn't ran for 24 years. It was running when parked back in 1996. I want to spin the crankshaft and check the compression. If the mechanical fuel injection system is gummed up with old fuel, can I damage the fuel injection system when I spin the crankshaft? Thanks in advance, Jack.
MikeSimon
  • USA, OH, North Royalton
Re: Hasn't run in 24 years
« Reply #1 on: August 14, 2020, 13:02:09 »
Eager to hear some answers about that.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: August 14, 2020, 14:38:17 »
I would suspect that the electric fuel pump is stuck, but I would pull the fuse for it so you do not circulate dirty fuel to the IP just in case it still runs. Pull all the spark plugs and squirt a little lube in the cylinders.
ejboyd5
  • Southold, NY
« Reply #3 on: August 14, 2020, 18:19:31 »
I would turn the engine over by hand before putting power ti it.
