Author Topic: Power steering pully  (Read 2559 times)
CJHenderson
  • USA, AR, Benton
« on: August 14, 2020, 20:36:39 »
Is there anywhere I can get a replacement Power Steering pully? Bent the other one while pulling it off?
1950 MG-TD
Re: Power steering pully
« Reply #1 on: August 15, 2020, 14:24:58 »
PM me if you like. I have lots of them.  Otherwise, they are the same and quite common on other MB models of the era.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: August 15, 2020, 16:24:14 »
Great thanks.
1950 MG-TD
johnk
  • USA, OH, Avon
« Reply #3 on: August 15, 2020, 22:27:12 »
I bent mine slightly to when pulling it off but was able to straighten it. Seems to work just fine, but my engine hasn’t run that much yet.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
chumps
  • USA, CA, Santa Rosa Valley
« Reply #4 on: August 15, 2020, 23:26:32 »
When I replaced mine a few years ago, I found that there were two different shafts on the pump. One is tapered and the other is straight. One was common and other was rarer I can't remember which one I had. Make sure you get the match for your shaft.
Chumps
rjmarco
  • USA, CA, Alamo
« Reply #5 on: August 16, 2020, 02:56:35 »
I had the same issue back in 2012 when my power steering pump pulley broke away from the shaft.  I found and replacement on eBay and was told back then that the 230SL and 250SL both had the straight shaft.  That is what I purchased and it was installed successfully.  No problems with my power steering since that time.
Rich
Alamo, CA
