Author Topic: W11X glovebox spring  (Read 2383 times)
col320ce
« on: August 21, 2020, 05:44:58 »
Is the spring mechanism on the w111 coupe glovebox on both hinges or just one?
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
cfm65@me.com
  • Cape Town, South Africa
Re: W11X glovebox spring
« Reply #1 on: August 21, 2020, 16:20:17 »
Hi Col,
I used to have a 61 Cabrio and 63 Coupe and if I remember correctly, the glovebox door is the same as the Pagoda. Only one long hinge and only one spring setup on the inboard side of the box. I say ‘inboard’ because my Cabrio was a lefty and the Coupe was a RHD.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: August 21, 2020, 19:40:48 »
There is only one spring on the box door. On my LHD, it is on the lower left corner of the door. Not sure if that changed with RHD. The mechanism is a bit different from the W113 in that there is only one fork and is loaded differently. Fork is #110 689 00 32 and the spring is #110 993 09 01 if you need those. I don't remember if it is a long hinge or two short ones.
I didn't take detailed pictures when I redid my dash. :(
col320ce
« Reply #3 on: August 22, 2020, 00:34:21 »
Thanks for the replies!
Col
1964 230SL
1965 250SE coupe
