Thank you again!
I do have this table and drawings in my BBB, section 33, where it belongs. I am a bit clumsy with BBB, sorry. I was in Alignment, section 40.
Yes, these are the parameters - 243mm and 1.5mm offset on bushings for 280SL. The drawings on how it should be put together are there.
I am afraid dismantling the king pin pivot, stabilizer and leaf springs will require work with springs (pivot), so I need to take the car to the shop to clean this up.
I already see that at MB leaf spring 248mm (non power steering, A 112 331 11 12) is available, but 243mm for power steering, A 112 331 00 12, is not...
Some vendors, e.g. SLS have one part number for bushings for 113, 108, 111 etc. No idea what the offset is there...
