Author Topic: mann fuel filter  (Read 2393 times)
Bob G MN
mann fuel filter
« on: August 26, 2020, 18:04:36 »
I.'ve read a lot about this but still a little confused. I bought a Mann P707 fuel filter.  The vendor said it included an o ring but no o ring in the box.  There were felt rings on top and bottom. Question is do I really need a new o ring or will the old one work (or is there really an o ring that needs to be used with this filter) Seems nuts if one is needed why Mann would no include one .
WRe
Re: mann fuel filter
« Reply #1 on: August 26, 2020, 18:24:13 »
there are 2 different Mann fuel filter:
- P707 w/o o-ring and
- P707x with o-ring (75 x 81,5mm) can bought separately.
I would use a new one.
...WRe
« Last Edit: August 26, 2020, 18:47:39 by WRe »
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #2 on: August 26, 2020, 19:27:22 »
hello Bob,
I agree with WRe and recommend replacing the O-Ring with the fuel filter. They're cheap ($.61) - you'd think Mann would include one with each filter but unfortunately, they don't.  I bought (3) from AutohausAZ just to have a couple extras on hand:
DPH Fuel Filter Seal; Fuel Filter Seal Ring for Cartridge Style Filter
P/N: 1009970040
3x $0.61
take care,, Charles
« Reply #3 on: August 26, 2020, 21:46:06 »
Fuel filters do not usually come with a seal. You will have to order it as a special part. It is a square rubber O-ring. I use some grease to glue it in the upper housing or it will fall off during installation.
« Last Edit: August 26, 2020, 21:57:15 by ja17 »
Bob G MN
« Reply #4 on: August 27, 2020, 00:21:18 »
Thanks Joe and others.  I'm still a little confused.  The canister for the filter is round so I thought the o ring would be round.  Where does a square ring go
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #5 on: August 27, 2020, 00:41:18 »
Square cross section.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #6 on: August 27, 2020, 00:52:02 »
Perhaps overkill, but attached are photos of the seal. I'll ask my wife to drop one in the mail for you,, just let me know.
Bob G MN
« Reply #7 on: August 27, 2020, 02:09:34 »
Thanks Charles
« Reply #8 on: August 27, 2020, 02:19:40 »
MB is strange like that.  When you need a complete kit, they only sell as separate items.  When you need separate items, it only comes as a kit. ::)
Jordan
  • Canada, ON, Jordan
« Reply #9 on: August 27, 2020, 10:55:44 »
And while it might seem obvious, make sure the old o-ring is out.  When I did my first oil change many moons ago I found 2 o-rings in the slot.  They are hard to see and it is easy to think there is no o-ring up there and put the new one over the old one.
Marcus
66 230SL  Euro 4 speed
« Reply #10 on: August 27, 2020, 15:00:49 »
Marcus,
Excellent point. Having the second O-ring in there can also lead to cracking of the housing - tightening too much.
