Author Topic: Temperature gauge reading  (Read 1530 times)
GM
  • USA, CA, San Pedro
« on: September 02, 2020, 17:54:45 »
Took my car out for a spin this morning - 70° clear at the beach - and the temp gauge is showing low temp after 30 minutes of driving. The level doesn't rise above the mid-point hash mark between the bottom square and the 180°F square, where it used to run constantly. Heater works fine.
A little history:
- 4 months ago had the same problem, so I replaced the thermostat (79°, MB part)
- temp continued to drop until went to zero
- took out the temp gauge and sent to PA Speedo for repair
- installed repaired gauge/probe, temp went to 180°
- for the past few drives temp has been lower again
So now I don't know (1) is it ok to run where it is, (2) might my thermostat be defective, and should I replace it again, or (3) do I need to look at something else?
« Last Edit: September 02, 2020, 21:51:58 by GM »
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
GM
Re: Temperature gauge reading
« Reply #1 on: September 03, 2020, 20:13:53 »
Any help?
Gary
1971 280SL - Sold
Black MB Tex
« Reply #2 on: September 03, 2020, 23:19:20 »
Sounds like all of the gas leaked out of your gauge. Once it's empty it won't work at all. I would send it back - they will fix it for you.
GM
« Reply #3 on: September 04, 2020, 01:15:01 »
Ugh - that's worse than replacing the thermostat! Thanks, I guess... :o
Gary
1971 280SL - Sold
Black MB Tex
