Author Topic: Auto Gearbox repair kit or overhaul  (Read 1876 times)
Mohan58
  • Malaysia, Selangor, Petaling Jaya
« on: September 11, 2020, 01:03:41 »
Hi all,
Has anyone done an overhaul for your auto gearbox? My auto gearbox slips sometimes & also judders. Believe the juddering is due to the propeller shaft coupling that needs to be changed. I also have a jerk every time i go from neutral to drive.
If you have done a gearbox overhaul, would you have a list of parts that you changed or bought a repair kit.
Mohan
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Auto Gearbox repair kit or overhaul
« Reply #1 on: September 11, 2020, 17:58:34 »
jerk?
How high is your idle?
« Reply #2 on: September 11, 2020, 18:50:45 »
Have you tried oil change and tuning the transmission? Perhaps try this first.
Please remember that in these cars if idle is wrong, gear shifts may be wrong too. It is interconnected.
Mohan58
« Reply #3 on: September 12, 2020, 02:20:50 »
thanks for the info. It slips when u start moving off. Oil is all new. Did not know about the tuning part. Engine has been tuned.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Mohan58
« Reply #4 on: September 12, 2020, 02:22:27 »
Idle is not high. At times it is as i have a leak in the master pump. When i press the brakes, i hear air noises. That will be rectified once she goes in for the gearbox.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
« Reply #5 on: September 12, 2020, 07:53:31 »
By tuning I meant checking/adjusting the correct pressure in the gearbox.
If you press the brake and hear air noise, your booster may be leaking, which is affecting the vacuum in the manifold, which is affecting how gearbox operates. So probably the booster may need to be checked/fixed first.
How did the old oil look like? Smelled like?
I am not an expert - perhaps your gearbox is indeed up for overhaul and slipping on start may be a clear symptom of that - I am not sure.
« Reply #6 on: September 12, 2020, 08:04:42 »
There are quite a few things I would check before calling the gearbox deceased. The Correct operation of the three position solenoid Would be the first.  This is well documented here.
The control pressure would be the next along with idle speed and correct adjustment of the idle switch.
Mohan58
« Reply #7 on: September 17, 2020, 09:13:38 »
Thanks so much for the heads up. Will definitely look at all this first.
Cheers
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
