Author Topic: Crankshaft mounting hub paint  (Read 1747 times)
CJHenderson
  • USA, AR, Benton
« on: September 11, 2020, 14:30:29 »
Is there a special coating for the crankshaft mounting hub? I noticed that the coating on the mounting hub felt like it had a rubber type coating.
1950 MG-TD
Re: Crankshaft mounting hub paint
« Reply #1 on: September 12, 2020, 08:15:16 »
The two halves of the hub act at a vibration damper and are bonded into one assembly at the factory by a layer of vulcanized rubber.  What you see is most likely flash from the vulcanizing process and not an intentional coating.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: September 12, 2020, 12:33:06 »
Then the next question is, most of this rubber is gone and am not sure on how to proceed.
1950 MG-TD
« Reply #3 on: September 12, 2020, 18:02:37 »
The rubber is actually between two plates if you poke at the edge of the disc you will feel it. Anything on the surface is superfluous. Clean it up, paint it black, put it back on.
CJHenderson
  • USA, AR, Benton
« Reply #4 on: September 12, 2020, 19:54:50 »
Yeah that's the problem though, whoever had this car had the engine apart and scraped the insides.
1950 MG-TD
« Reply #5 on: September 13, 2020, 01:54:40 »
Picture?
CJHenderson
  • USA, AR, Benton
« Reply #6 on: September 13, 2020, 16:06:52 »
Here is the back side.
1950 MG-TD
« Reply #7 on: September 15, 2020, 09:44:29 »
There was no rubber in the inside of the 6 pointed star area.  At the very edge of the entire assembly you will find the rubber.  it is sandwiched between the Aluminum and steel layers.
CJHenderson
  • USA, AR, Benton
« Reply #8 on: September 15, 2020, 13:48:42 »
Yes and the rubber is gone on the sides.
1950 MG-TD
