When I said the engines run rich, that is primarily at idle. In the other higher ranges, it leans out. Keep in mind that the BC changes the mixture for all RPM ranges including idle speed. In the idle speed range, there is a seperate adjustment on the FI pump. If you want to change the idle speed mixture, the knob on the back of the FIP is what you want to use. Do not adjust when the engine is running though. Bad things will happen!!!! The split linkage test is most effective for idle speed but can also be used for RPM ranges higher than that.
Checking the plugs would give you an idea about the mixture for all ranges, not just idle. So I guess you need to determine where you think the mixture is off. As a general rule, you want to make sure ALL of the tuning is done first (plugs, points, timing, valve adjustment, throttle linkage etc..... ) before addressing the mixture. Then I would start at the upper ranges first by using the BC. Then focus on the idle and finally the mixture when cold by using oval shims on the WRD.
You might want to mess around with the FIP tuning simulation in the tech section. It will help understand how all of the functions of the FIP effect fuel mixture.
