Author Topic: 280Sl upper seat belt mount cover?  (Read 14096 times)
« on: October 03, 2020, 03:41:29 »
Another one of those areas that rarely gets photographed.  I am in the process of installing my seat belts and I have a question.  When I bought my buckles I also received a pair of black plastic covers that are supposed to snap onto the upper mount plate covering the mounting bolt.  Is this correct for a late 280SL with Kangol belts or should the plate just be left bare?
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: 280Sl upper seat belt mount cover?
« Reply #1 on: October 03, 2020, 03:52:40 »
I far as I know there were never covers for the upper hardware on pagodas.  I have seen aftermarket ones or for later cars.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: October 03, 2020, 08:09:10 »
For what it is worth, this is from EPC, from chassis 113.044 000656
A 000 868 00 30
Not claiming it is correct, etc., just what the system is saying. I guess the US mainly.
mrfatboy
    • Mrfatboy
« Reply #3 on: October 03, 2020, 10:37:07 »
Pawel,
Are you referring to something like this?
https://www.ebay.com/itm/293722720288
The eBay ad mentions 113 but you know how that goes 🤣
When I redid my seat belts I looked into the covers but was told 113 didn’t have them. I seem to remember someone put them on to look good but when you did you could no longer hang the belt on the upper bracket for storage like it was originally designed 🤷‍♂️
I will interested to hear others opinions.
Signal Red
4 Speed
« Reply #4 on: October 03, 2020, 10:57:29 »
Yes, I think EPC indicates something like these black plastic covers. I could not spot them at the time I fit my belts. I used those metal ones, then I just put magnet on buckles and leave them on the sill.
Yes, it was generally said 113 did not have the covers. But the EPC says otherwise, the chassis number I quoted is from the footnote for the part number.
I am not pushing this idea, just provided what the system says. This is for 3point belts that were anyway rare, I suppose. It says it is US. I think there were not a lot of them, but in my view, they were there if the car had 3point belts for the US.
« Reply #5 on: October 03, 2020, 21:30:57 »
Thanks for the responses.  I am trying to decide if I am going to use them.  It would seem like they would fall off easily.  Maybe I'll put them on for showing only.
« Reply #6 on: October 04, 2020, 05:43:47 »
Pat,
I assume you are using static retracting 3-point belts, correct? As long as the belt hangs down they will stay put. But they interfere with the rotation of the bracket that you need for the belt to function.
{typo corrected}
« Last Edit: October 04, 2020, 18:41:22 by 66andBlue »
« Reply #7 on: October 04, 2020, 12:33:43 »
I do not have the original bracket for the top achor point, I could not get it and I used what the factory who did my belts gave me. My current bracket is similar in shape to the original one (you see it is modern, just overall shape idea is similar) and I have it facing differently - forward and up, otherwise it was very inconvenient to use. I think I made additional L shaped bracket there to have it facing the right direction.
You need to try to fit it and see how it works, but if I took the bracket from Alfred's picture, I would turn it upside down - that would make it closer to what I have.
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #8 on: October 04, 2020, 15:38:38 »
Oh guys, TIME OUT.
Rarely am I ahead of the curve when compared to Alfred, but I must tell you, that my extremely original Anthracite (sold) 280 SL had the covers as pictured in the parts breakdown and the ebay link shown previously in this thread by mrfatboy.
AND, if you look closely at thelews (John) very original 250 SL, he has them installed where they should be. Look at the link on any of his posts. It is picture DSCN3158.
Shvegel, they are correct !!
Take care,
Mark
1998 BMW M-Rdstr Estoril Blue
« Reply #9 on: October 04, 2020, 16:00:36 »
Yes, that is how I would imagine the original look of it, thank you!
I think close to what Alfred posted, actually.
scoot
  • USA, CA, Altadena
« Reply #10 on: October 04, 2020, 16:30:12 »
You should put on the plastic covers.  They don't fall off.   The pictures in this thread that are showing retracting belts are not relevant to your application of Kangol 3 point static belts.
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #11 on: October 04, 2020, 19:26:12 »
Thanks Scott, I corrected my post since I had retracting belts in mind.
My 230SL came without seat belts or head rests. So when Joe A. worked on it we decided to put retracting belts in but using a better solution for the guide on top of the B-pillar. He used belts that are on W201 cars and others of that time since they have a better designed guide arrangements (photo 1).
Later I changed the belt out for Kangols and am very happy with the looks and the smooth operation. There is even a way to hang up the belt end when not in use.
scoot
  • USA, CA, Altadena
« Reply #12 on: October 04, 2020, 19:33:44 »
Retracting Kangols.  Rare.  Nice.
Scott Allen
'67 250 SL (early)
neelyrc
  • USA, AL, Birmingham
« Reply #13 on: October 05, 2020, 02:35:27 »
As delivered (except for the dust).
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
« Reply #14 on: October 05, 2020, 05:05:24 »
Just curious: is VIN above or below 113.044 000656?
I would not expect consistency here with what the system is saying, just curious.
MikeSimon
  • USA, OH, North Royalton
« Reply #15 on: October 05, 2020, 12:55:45 »
My 1971 280SL  ..22774 came without seat belts because it is a German spec car and belts were not mandatory in Germany at that time. I have done some extensive searching for ways to install seat belts in my car and I can say that I did not find any evidence that W113s came with retractable seat belts from the factory.  They were all aftermarket. Installation is sort of a mess and for some versions require cutting of the B Pillar cover at the bottom to hide the spool housing. All the non-retractable seat belt versions I have seen had the top plastic cover. Note that the bracket varies depending on whether the belt has to slide through it (retractable) or is fixed there (non-retractable)
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
mrfatboy
    • Mrfatboy
« Reply #16 on: October 05, 2020, 18:45:21 »
This subject is definitely a head scratcher.  I now suspect that the statements “never had covers” and “always had covers” are both incorrect.  The truth probably lies somewhere in the middle and this thread will be right up there with the “what is the correct wiper blades?” and “What is the correct radio?” thread debates.
These types of discussions are fun and one of the main reasons why I like to participate on the forum.
Over the weekend our San Diego group put our heads together to try to narrow down seatbelt originality.
First off, Box 43 on there data card (upper right corner) indicates the safety belt option that came with your car.
43(-)  - No belts (Dealer installed?)
43(0) – Safety Belt 3 point  (Kangol, France Only)
43(1) - Safety Belts, 2 point
43(2) – Safety Belts, 2 point
43(4) – Safety Belts, US- version
43(5) - Safety Belts, US- version
The above information comes from the Parts Book mentioned below.
I went over several data cards that have been posted here on the forum as well as our local group’s.
49er, Neelryc, JonB, TylerS,  mine and several others had no code in Box 43 except for one.  The one that had the code was an early 250sl.  It had code 43(4) in the box.  At this time I do not know if they were lap belts or 3 point static.  I am guessing lap belts because I was told that US 250sl’s did not ship 3 point static belts from the factory.  Can anybody confirm?
So it would seem many of these belts were installed at the dealer.  Did they have different versions to choose from? Just what’s available?
TheLew’s early 250sl pic above throws a wrench in the above premise.  However, are we absolutely certain that his belts are original? How do we know if he didn’t upgrade later on?  How did he get 3 point static for a 250?  Did he special order?  Data Card? I would like to see the manufaturering data on belt itself.  Hopefully he can chime in on this.
For discussion purposes we need to consider several things – Factory Installed, Special Order, Dealer Installed, US vs Euro, Replacements, and different versions.
Just a note, an original USA Version 250sl & 280sl edition A 1972 10808 parts book was reviewed and the only reference to seatbelts was the SA55686 code that Pawel referenced above. However, there were no pictures or part numbers for the belts.  Other early parts books were reviewed and there were no references to seat belts at all.
I came across this post by Scoot in 2008 that has much info about the belts.
https://www.sl113.org/forums/index.php?topic=9986.0
An excerpt
“If they are chrome (particularly for the shoulder) they also have a big chrome bolt holding it in and the head of the bolt is "thin" compared to most bolts.  A thicker-headed bolt would be used in other locations where it is not visible.   On later cars, the shoulder connector would be covered with a plastic thing like in the pictures above.  In this case the connector and bolt would probably not be chrome. “
So it would seem there are at least two versions of the 3 point static belts.  Early version has thin chrome bolt and does not have the plastic cap and the later version of none chrome bolt that cap can fit on.
As a data point, one of our group’s cars is a Sept 69 280sl with the non chromed bolt on the B pillar which would suggest that a plastic cap was required. If I remember correctly, Neelryc’s car is a ~Feb 69 280sl and has the chrome bolt which didn’t come with the cap.  So we sort of narrowing in on the date range.
Also, to confuse things even more, since the belts seemed to be mostly dealer installed who knows what belts they had on hand at the time, all parts installed, etc.
If possible, it would be great if people could post their data card code, seat belt type, US/Euro,  Year and the manufaturering date on the tag on the belt.  It will be the black/white tag (not red color Kangol) with the date in the lower right hand corner.  The tag may also indicate "This belt conforms to US Federal Moto Vehicle Safety etc".
There is much more to all of this and once again I learned something new about the pagoda 😊  I look forward to other’s opinions.
I have attached a picture of my B pillar belt hardware.
Signal Red
4 Speed
MikeSimon
« Reply #17 on: October 05, 2020, 18:59:03 »
One other point that may help clarify some questions, especially lap belt vs 3-point on earlier cars; My car, although no seat belts, has a factory installed top mounting point in the B-pillar.
So, if someone has a 250SL with a 3-point belt and the top mounting nut inside the pillar seems to be an "afterthought" the car was built for lap belt.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
GM
  • USA, CA, San Pedro
« Reply #18 on: October 05, 2020, 19:24:13 »
My '71 280SL US car, production date February 19, 1971 (98 before the end of production) has Kangol original 3-point, non-retractable seatbelts. My Vehicle Master Inquiry (VMI) doesn't show seatbelts as an option.
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
mrfatboy
    • Mrfatboy
« Reply #19 on: October 05, 2020, 19:27:28 »
Do you have the thin chrome bolt at B pillar or non chrome bolt? I assume no cap?
What does your tag say?
Signal Red
4 Speed
GM
« Reply #20 on: October 05, 2020, 19:45:18 »
Non-chrome bolt, no cap.
Here's what's left of one label (other gone) - good luck reading it!
« Last Edit: October 05, 2020, 20:30:35 by GM »
Gary
1971 280SL - Sold
Black MB Tex
mrfatboy
    • Mrfatboy
« Reply #21 on: October 05, 2020, 19:58:27 »
Yes. Hard to read. Looks like 1970 or 1976. If 70, most likely original. If 1976 not so much 🤣
It would seem your belts require the plastic caps but don’t run out and buy just yet.
One of our group has a spare set of plastic caps and want to try them on a sept 69 car and see if they fit.
Signal Red
4 Speed
MikeSimon
« Reply #22 on: October 05, 2020, 20:07:46 »
The label is in English. That would indicate non-factory??
Interesting bit: My haynes manual on pg 169 talks about a seat-belt warning system:
24 Seat belt warning system
1 cars covered by this manual and destined for operation in North America are fitted with a simple type of seat belt warning system.
4 Switches are located in the seat belt retractor units...
A picture, Fig.10.11 shows a retractor
One large picture over two pages in the 280SL original sales brochure shows a red car with black hubcaps, top open, a woman driving, a plastic cover over the top belt bracket.
« Last Edit: October 05, 2020, 20:27:52 by MikeSimon »
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #23 on: October 05, 2020, 21:30:54 »
My 250sl came with the 3 point provision  with caged nut in the B-pillar even though it only had lap belts installed (3rd party dealer) It is blanked off with a plastic plug.
« Reply #24 on: October 06, 2020, 00:12:28 »
The mounting point on top of the B-pillar was there almost right from the start, first with a 10mm and later with a 7/16inch thread. A second point was across on the tunnel, both were used for shoulder belts, NOT lap belts.  It might help to read the factory information here:
https://www.sl113.org/wiki/Interior/Seatbelts
In the discussion here it will be helpful if owners with original 3-point static belts indicate whether these are Mercedes belts or Kangol belts.
Another question I have for these owners is whether the belts are rotated up on the top of the B-pillar or remain in the downward position while driving.
The Kangol installation instructions (unfortunately in German only) issued by MB indicate an upward position.
How many of you use the metal belt hangers?
Ralf and Gary (GM), how do you put them on, up or down?
