Author Topic: can 215/14 tires safely work on a 280SL  (Read 3406 times)
Green68MB
  • USA, NC, Taylorsville
« on: October 06, 2020, 21:31:06 »
  Even though the 185 is the tire on record, I have also enjoyed up sizing to 205/14's.  Will a 215 also fit successfully?
lowpad
  • USA, CT, New Preston
Re: can 215/14 tires safely work on a 280SL
« Reply #1 on: October 08, 2020, 01:48:42 »
I have 205s on my car (on alloys) and 185s on steelies.  I think the 205s are just a little bit too large (ie, tall) and the 185s are a little too small.  Perhaps 195/70s are the ideal size ....
You will find many discussions on this topic in the forum.  Some have suggested that the extra weight of the larger tires increases wear on chassis components, but I haven't seen any science on that -- I expect that there is a single-digit pound weight increase over the 185s and I doubt that our very robust Pagodas would have a significant issue with this, but I'm open to anyone that has data to show that there's an actual mechanical impact vs. the stock tire size.
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
WRe
« Reply #2 on: October 08, 2020, 07:15:06 »
which is often not considered that the enlargement of the tires leads to an additional load on the frame and suspension.
In this context, I have heard of a damage pattern that occurred directly when using larger tires. Due to the increased load of larger tires, the power steering with the sleeves was torn from the frame or the fastening screws broke off, caused by operating the steering while the vehicle was stationary, the frame moved back and forth up some millimeters. After these cases occured a reinforcement bracket was welded to the frame.
Nevertheless you should be careful!
...WRe
« Last Edit: October 08, 2020, 08:25:55 by WRe »
Green68MB
« Reply #3 on: October 08, 2020, 17:36:27 »
 The dwindling market for 205/14 tires   and an increase in available 215/14's was the basis for this question.
  I have been using the 205's on alloys for over 15 years without any issues.
 I just like the idea of a wider footprint, but don't want to rub the wheelwells.
  I did have a power steering seal dry and was replaced- only issue after 50 yrs. .  Car sits more than being driven.  Thanks
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
« Reply #4 on: October 08, 2020, 17:54:09 »
Or use 15 inch rims
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
doitwright
  • USA, IL, Willowbrook
« Reply #5 on: October 08, 2020, 18:59:51 »
Do you have hub caps to go with those 15" rims?
Frank Koronkiewicz
Willowbrook, Illinois
