Author Topic: Accelerator pedel mount welded to floor or free floatin?  (Read 2382 times)
Green68MB
  • USA, NC, Taylorsville
« on: October 08, 2020, 17:23:58 »
Is the accelerator pedal mount welded to the floor panel or is it just attached to the rubber pedal?  When I pulled up my carpeting , I found rust at the exact area and wondered if it broke loose or was never attached.  Any info is appreciated. Thanks
dirkbalter
  • USA, CA, Corona
Re: Accelerator pedel mount welded to floor or free floatin?
« Reply #1 on: October 08, 2020, 18:31:14 »
Its welded to the floor.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Green68MB
« Reply #2 on: October 11, 2020, 15:11:49 »
Thanks, After I pulled the carpet up the mount was loose and still attached to the rubber  pedal.
dirkbalter
  • USA, CA, Corona
« Reply #3 on: October 11, 2020, 19:48:08 »
If your floor panels are still strong enough, you can weld it back in. I took some dimensions before I removed my bracket and can post them if needed.
(Not sure if I would go that route but if welding is not an option, you could probably drill holes and screw the bracket to the floor.)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Green68MB
« Reply #4 on: October 14, 2020, 18:10:59 »
Thanks, the screw  solution seems  most probable
swood1
« Reply #5 on: October 18, 2020, 22:03:58 »
Hi Dirk,
Would you mind posting your dimensions please?  I am just going through process of replacing my floor panels.  The original bracket was missing.
Regards
Steven
dirkbalter
  • USA, CA, Corona
« Reply #6 on: October 19, 2020, 22:05:02 »
Steven,
The dimensions I wrote down before I cut the floors out:
3 3/4" (85.7mm) from the tunnel wall to the outer edge. See pic
2 1/4" (57.1mm) from the transition of the floor panels  to the front edge of the bracket. See pic
Hope that helps
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
swood1
« Reply #7 on: October 24, 2020, 10:11:24 »
Hi Dirk,
Thanks very much for this information.
Kind Regards
Steven
