Author Topic: CW or CCW  (Read 2961 times)
Ed Fisher
CW or CCW
« on: April 05, 2005, 06:35:16 »
Good morning all.  I have my points set to a 34-38º dwell angle and I am trying to fine tune the timing.  Right now I have a slight bit of pinking, but the car is running well otherwise.  Looking down from the top of the distributor, do I rotate CW or CCW from this point to stop this?  The reason I ask is due to the difficulty of removing the battery for access to the pinch screw.  Can't quite get to it with the car at operating temperatures without scalding my forearm with the battery still in place.  Thanks,  Ed Fisher Dallas, Texas
Re: CW or CCW
« Reply #1 on: April 05, 2005, 06:45:04 »
CW to retard.
You may want to turn the collar around. See:
http://index.php?topic=2516
« Last Edit: April 05, 2005, 06:55:22 by naj »
Ed Fisher
Re: CW or CCW
« Reply #2 on: April 05, 2005, 07:02:17 »
Thanks Naj.  Does the collar simply rotate, or must the distributor be removed to facilitate movement?  Ed
Re: CW or CCW
« Reply #3 on: April 05, 2005, 07:14:06 »
Ed,
To do what the engineer has done (see picture with his post), you'll have to remove distributor to 'flip over' the locking collar. [:(!]
