Author Topic: WTB Main & Rod Bearing Set for M130 Engine  (Read 3077 times)
SEB
  • Germany, Berlin, Berlin
« on: October 21, 2020, 14:13:22 »
Hello everyone,
I am looking for a set of :
1. Main Bearings for the 280SL +050mm, 2nd repair
2. And the Rod Bearing Set for 280SL +25mm, 1st repair.
Also for some inputs or tips, where I can get such bearings  for resonable price in the US or Europe I will be very grateful.
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
Re: WTB Main & Rod Bearing Set for M130 Engine
« Reply #1 on: October 21, 2020, 16:40:05 »
You can buy them direct from Mercedes.
You can also buy much cheaper ones from after market suppliers there in Germany but I would strongly urge you not to. Tolerances are not good on after-market bearings.
SEB
« Reply #2 on: October 21, 2020, 18:44:16 »
The suppliers on the German market I know, but the problem is, that until end of this year no one will have it in Germany on stock . That's why also this question?
Sebastian
« Reply #3 on: October 28, 2020, 15:50:49 »
Do you have the part numbers you are looking for?
SEB
« Reply #4 on: November 04, 2020, 18:03:30 »
Here you are:
Crankshaft bearing second repair level- 130 030 0240
Rod bearing first repair 47,75mm -       114 030 0060
Question? Are only the rod bearings from M114 and M110 fit to the M130 engine or also the crankshaft bearing?
Can I here in this forum find also the direct OEM parts number from GLYCO or Kolbenschmidt?
Sebastian
