Author Topic: W111 (&W113 230SL) Febi Flex Disc  (Read 3613 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: October 22, 2020, 21:42:44 »
Hi all,
I removed my flex disc (original Mercedes it seems) as I am having my prop shaft overhauled. I had bought a Febi replacement and to my surprise it was quite different when I removed it from the box.
The original mercedes part was as described in the Tech Manual / forum posts with a uniquely identifiable face to be fitted to the transmission side. Correct fitting assures the links are in tension rather than compression apparently.
The Febi one looks absolutely symetrical with no identfiable sides. Has anybody fitted one of these? Febi part number 14930.
Regards
1963 220se Cabrio
1968 280se Coupe
Re: W111 (&W113 230SL) Febi Flex Disc
« Reply #1 on: October 22, 2020, 21:54:50 »
That's the new replacement. No indexing required. You're good to go.
dirkbalter
  • USA, CA, Corona
« Reply #2 on: October 22, 2020, 22:45:06 »
Peter,
I bought and fitted the same (Febi) . As Benz Dr. already said, it can go either way. There is an article about it somewhere around but I don't remember where.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
PeterPortugal
« Reply #3 on: October 23, 2020, 06:20:03 »
Gents,
Thanks for your advice. I thought I was going to end up with yet another incorrect new part gathering dust on the shelf.
Regards
1963 220se Cabrio
1968 280se Coupe
« Reply #4 on: October 23, 2020, 06:42:20 »
The new flex discs are more robust also and should last longer.
JPMOSE
  • USA, DE, Harbeson
« Reply #5 on: October 27, 2020, 10:28:10 »
The one I bought from the classic center was different as well.
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
TJMart
  • USA, NC, Matthews
« Reply #6 on: August 05, 2021, 20:55:18 »
Is the Febi Flex Disc the equivalent to the Mercedes Disc. Does it last as long or longer than the MB one? I think I saw where SGF makes both of them?
Tony
1970 280SL, 4 Speed
« Reply #7 on: August 09, 2021, 04:56:07 »
Show us a picture and we will be able to tell you.
TJMart
  • USA, NC, Matthews
« Reply #8 on: August 11, 2021, 18:36:04 »
Joe,
I ordered the MB one from the Classic center. I paid $58 which was cheaper than the Febi one. Here is the picture of the MB Disc. It appears to look the same as the Febi. It shows that SGF made it and has the MB logo and part number. Based on your experience is there a difference between the MB vs Febi?
Thanks!
« Last Edit: August 11, 2021, 18:40:30 by TJMart »
Tony
1970 280SL, 4 Speed
« Reply #9 on: August 13, 2021, 05:15:46 »
That's the new version TJ. It's much better than the originals and you cannot go wrong with the MB brand.  The new improved version is also less expensive and that must be a first!
« Reply #10 on: August 13, 2021, 05:33:42 »
I would like to point out that at MB PN  A 108 410 01 15 is the repair kit and it comes with seal rings and bolts.
TJMart
  • USA, NC, Matthews
« Reply #11 on: August 13, 2021, 21:08:13 »
Pawel,
I checked on that kit with the Classic Center here in USA and it is NLA and you have to order all parts of the kit separately. May be different where you are.
Tony
1970 280SL, 4 Speed
« Reply #12 on: August 13, 2021, 21:24:41 »
I hate that with MB. When you need a kit, they make you buy a lot of separate parts. When you only want one part, they insist that you buy the complete assembly. >:(
« Reply #13 on: August 14, 2021, 07:17:27 »
Pawel,
It is a kit here, ca $80. Parts list doe snot even have the PN for flex disc.
Well it is trading up on one hand, on the other hand I think I read an opinion here it was a good idea to use the new bolts and seals... I do not appreciate some of the ridiculous pricing from them even though I fully understand need for margin...
