Author Topic: Dead Gear Shift on Automatic?  (Read 3396 times)
Theo113
« on: October 24, 2020, 13:33:52 »
Of course like many other problems there was no indication of a problem until last evening the Gear Shift did nothing.  Not able to engage a gear, or to start, or for park to hold the car.  The shifter moved extremely easy between selections with no results.  Could this be that the linkage between the selector and the gear box broke?  Any other thoughts?
WRe
Re: Dead Gear Shift on Automatic?
« Reply #1 on: October 24, 2020, 13:58:59 »
a well known problem is a damage of a round plastic shift bushing that connects the shift gate to the shift linkage, see https://www.sl113.org/wiki/TransmissionClutch/Shifter#Auto_ShiftGate.
...WRe
Theo113
« Reply #2 on: October 24, 2020, 14:02:39 »
WRe -   Thank you for the, hopefully, good news and references regarding same.  Much appreciated!
« Reply #3 on: October 25, 2020, 01:05:32 »
The bushings on the linkage for the Auto trans fall apart. You will need 2.  The small end goes toward the lever.
Theo113
« Reply #4 on: October 25, 2020, 12:01:54 »
Shvegel,  thanks for the additional information regarding the potential parts needed.  Your comments are appreciated.
« Reply #5 on: October 25, 2020, 15:20:53 »
A few plastic wire ties will get you back on the road temporarily, in an emergency.
Theo113
« Reply #6 on: October 25, 2020, 16:07:07 »
ja17.....Thanks for the quick temporary fix.  Might be helpful short term.  Much appreciated!
